- (323.35 KiB)
I was fitting out a new workshop last October and needed a bench. I went to a well-known purveyor of tools and equipment, to find that a piece of lightweight wobbly nonsense (that was six inches too low) would set me back £385. Off to the local timber recycling project.
They had some 3x4 and 6x4 from a demolition site, much of it covered in cement, but cheap, and they had enough to do the top and base. I fancied trying a Swedish style because in the past I always seemed to be running into the vice screws with regular vices. Also wanted some dogholes for workholding. Knockdown construction for the base, because I'll be moving lock, stock in a year or two. I'm going to make some musical instruments, small cabinets and some bits and pieces for the house, nothing too large or heavy, so figured that softwood would do the trick.
The design came from Sam Allen's 'Making Workbenches',
available here but I changed all the dimensions as I was going along to suit the stock I had. It's turned out a bit beefier than the plans (because softwood). The vice hardware came from Axminster and is fine, but if fitting a tail vice like this, double-check the hole positions for the screw and guides. I did, but still managed to get them slightly off. Maybe it's just me. The top has several coats of finishing oil, so glue doesn't stick. The base has been left unfinished 'cos life's too short.
I kept a rough track of the time spent and it owes me about 45 hours. Would have been quite a bit quicker if I had a planer/thicknesser. (I've got one on order now, but it's stuck somewhere behind the Ever Given.) The materials cost me about £140 including the vice hardware and a fiver for glue. I'm retired, so my time's my own. It's been good to work on, but a bit wobbly at the skinny end; the top twists surprisingly easily with sideways pressure.
I originally finished it in November, and have just now replaced the stretchers in the base with a storage cabinet. That has stiffened it up considerably and, once I have put some heavy stuff in there, it's going nowhere. Also added a tool tray (for shavings, obvs). Storage cabinet from CLS and ply from Wickes, with birch ply offcuts for the doors. Surprised to find the CLS had gone up 50% in price since the end of last year.
- (297.79 KiB)
- (256.5 KiB)
