It is currently 29 Mar 2024, 07:18
9fingers wrote:The issue of LED panels seems to be the reliability of the power supply module that has to be used to power each one. No one here has had them running long enough to get useful reliability of the panels themselves.......
Mike G wrote:9fingers wrote:The issue of LED panels seems to be the reliability of the power supply module that has to be used to power each one. No one here has had them running long enough to get useful reliability of the panels themselves.......
I've got one failing panel, and the replacement doesn't work at all.
RogerS wrote:Mike G wrote:9fingers wrote:The issue of LED panels seems to be the reliability of the power supply module that has to be used to power each one. No one here has had them running long enough to get useful reliability of the panels themselves.......
Sadly another example of C³
Mike G wrote:RogerS wrote:Mike G wrote:I've got one failing panel, and the replacement doesn't work at all.
I'm guessing Cheap and Chinese are two of those three.
EssJay wrote:Rod
I was going to put 600mm x 600mm square LED panels in my garage but eventually decided against it due to one reason or another, instead I started looking around at LED replacement tubes. We have a CEF locally so I bought 5 LED tubes from them of varying lengths and it's like an operating theatre in there now
Highly recommended by me.
https://www.cef.co.uk/catalogue/products/4513535-18w-t8-4ft-led-tube-glass-6500k
Hope this helps
Steve
Mike G wrote:EssJay wrote:Rod
Hope this helps
Steve
How do they work with an existing neon fitting?
Mike G wrote:Thanks Bob. I have an area of the workshop that has a couple of neons but needs a little extra light, so I might swap to LEDs and see if that helps.
9fingers wrote:Mike G wrote:EssJay wrote:Rod
Hope this helps
Steve
Depends on the fitting Mike. If you have an old 50Hz ballast (heavy iron cored choke, capacitor and glow starter, then fit the "modified starter" that comes with the tube and then fit the tube. If you have modern high frequency ballasts with no starter then just fit the tube.
The tubes tend to come with instructions.
DaveL wrote:......If you want a hand installing some in your Workshop, just shout.
TrimTheKing wrote:Nice Rod.
Need a few coats of white on that ceiling...
Users browsing this forum: Majestic-12 [Bot] and 14 guests
