It is currently 28 Mar 2024, 10:16
DaveL wrote:I have used GT85 with good results in the past, just a quick spay, then wipe down with a paper towel.
Mike G wrote:DaveL wrote:I have used GT85 with good results in the past, just a quick spay, then wipe down with a paper towel.
Yep. And WD40, although it doesn't last an awfully long time. Also, a bike chain lube works.
Robert wrote:Not recommending it but I put some engine oil on some squeaky door hinges last week via an oil can then wiped off excess. All quiet now. will have to see how long it stays that way.
9fingers wrote:
WD40 is NOT a lubricant it is a water displacer.
novocaine wrote:Oh wait, creaks, sorry. Nothing to see here.
Dave R wrote:novocaine wrote:Oh wait, creaks, sorry. Nothing to see here.
I'm glad I swallowed my coffee first.
9fingers wrote:.....WD40 is NOT a lubricant it is a water displacer.....
Dave R wrote:Might be worth looking at the way the hinges are aligned. Typically hinges squeak because the axis of the hinge pin and barrels aren't aligned with the axis of rotation. Lubricating works for awhile but I don't think it's a long term solution. Try loosing the screws on the squeaky hinge a little and see if you can adjust the alignment so it stops squeaking. I've done that for a few of the hinges in our house and haven't had to oil any of them since. Shows how the house as settled a bit over time.
Users browsing this forum: TrimTheKing and 16 guests
