It is currently 28 Mar 2024, 16:13
Mike G wrote:The two fundamentals are to have an air gap and a breather membrane between with frame and the cladding, and to pick the sole plate up off the ground. Do this, and everything else is secondary.
woodstalker wrote:.........So the entire shed base is up off the ground, tick?
Then frame, membrane, counter batten and cladding from inside to outside? (with insect mesh at the top and bottom of the air gap)
The membrane could be thin orb i suppose?
I am just thinking i will need to build the rear wall flat before putting it up due to the proximity to the fence preventing me getting behind to do the cladding.
MY63 wrote:Can I suggest that you swap your stain for another of MikeG s ideas Bedec Barn paint is a little more expensive than stain but you get much better results it can also be thinned down with water to make it go further.
I painted all of my cladding before I put it on you could paint your back panel before installation and save a lot of hassle.
Mike G wrote:I'm sure I've drawn the corner detail somewhere. If you have the patience to go through my workshop build thread I am sure you'll see it in great detail.....but essentially I screw two bits of 3x1 together to form an L shape, and fix this to the corner such that it sticks out the same distance from each wall. The subtlety is that I rip one of the pieces (the outside one) to 63mm, as this is what works for the feather edge boards that I use.
