It is currently 29 Mar 2024, 00:05
9fingers wrote:Just picking one parameter, ceiling height, it can be helpful to be able to rotate a sheet of ply/mdf/osb etc corner to corner so maybe consider that to set your minimum height at least in one region of the shop.
RogerS wrote:9fingers wrote:Just picking one parameter, ceiling height, it can be helpful to be able to rotate a sheet of ply/mdf/osb etc corner to corner so maybe consider that to set your minimum height at least in one region of the shop.
Mmm..I have a different take on that. Sheets of plywood etc are best dealt with on the floor. On top of a sheet of Kingspan and a tracksaw.
I'd also plan to have space for an assembly table.
9fingers wrote:RogerS wrote:9fingers wrote:Just picking one parameter, ceiling height, it can be helpful to be able to rotate a sheet of ply/mdf/osb etc corner to corner so maybe consider that to set your minimum height at least in one region of the shop.
Maybe but depends on how much floor space you have. I have virtually none.
heimlaga wrote:.... so I will let them grow until I need them.
