'Hula' Engine.
Peri
Shropshire
Steve.
This is my take on the compressed air engine design by Philip Duclos, published in the book 'Steam & Stirling Engines You Can Build Vol2 (1994).
The original plans are in Imperial - to me that's OK for woodwork, but for precision my mind works in metric :)
First, I built the model in Inventor, tweaking the measurements to give 'nice' decimal numbers, and replacing screws and bolts with the nearest metric equivalent.
Did a simulated run to see if it looked like it would actually work and not bottom out somewhere.
[youtubessl]aa3VcRBzlTg[/youtubessl]
Then make drawings for each part.
Everything was made from scrap bar or square stock.
I still have to dismantle it to give it all a good polish, but it's practically finished, all that's left to do is tap the air inlet valve to M5 and attach a permanent air line fixing.
It turns fairly freely by hand - tbh I was very surprised !
And finally, just because I had the computer model, a nice render :)
My goodness, that's stunning. Now, it's fine to test using compressed air, but I DEMAND that you run this on steam!! :)
Well that is very delightful.
We need a video of it running once its all hooked up. Perhaps on a repeating gif as im positive that watching that crank spin will be a wonderful hypnotic sight.
Well woodwork it ain’t but who cares. Thanks for sharing. Defo need a video. I guess it doesn't make much noise.
Do you plan to hook it up to something?
Thank you :)
The original article does suggest running it on steam - to be honest I wouldn't have a clue where to even start with that !
Once it's got an airline attached I'll be sure to do a video, although I'm expecting to have to bolt it to the table !
Sorry Andy - I just saw the 'Projects' heading and thought 'That'll do' ! :)
It'll be given a blast of air to see if it really does run, then a final polish before being put into the display case that people have to pass on their way to our engineering classrooms.
Fascinating :)
You must have quite a machine shop to go with the obvious engineering and CAD skills.
I just realised you can't really tell the scale of it. The base is 4" across and the cylinder socket screws are M2.5 (3-48 UNC)
Rob, I've been working in the engineering department of a college for the last 5 years - before that I'd never done any metal work at all. At 45 I taught myself CAD, then went to college to get some paperwork to prove I could do it, and ended up doing some voluntary teaching. As a 'thank you' the college paid for me to do my basic teaching qualification, and after 6 months or so took me on as part of the staff.
Ian - I'm now looking for a new project, if you've got any drawings......... :text-lol:
I think you have answered your own question. Must be plenty of resources out there for model steam engines.
Whatever you do please don’t hesitate to post details here.
Stunning! I haven’t a clue what one would be used for, and in the example of model aeroplanes I can’t think where the compressed air source would come from when it’s up in the air, but regardless, stunning!
Can’t wait to see the video.
Considering it weighs well over 2.5kg (5-6 ilbs) you'd need a lot of balsa wood to keep it airborne !
