Finished today, a Japanese Tea Cabinet; constructed from Brown Oak veneers over a lipped, laminated pine core. All the construction is with long ply splines aka Alan Peters; no dominos, no biscuits, no trad joinery. Even the 8mm thick shelves and partitions are joined with 3mm thick ply splines.
Shelves and partitions aren't flush either; most are set 2mm lower than others which made for an 'interesting' build
The back is veneered Brown Oak with a....
...thick pine backing veneer and is glued, screwed and nailed to the carcase. The cabinet is hung using some Haflé cabinet hangers which I've had for the last twenty years and never used :lol: There are two drawers which appear :eusa-whistle: to be 'standard' but each has...
...separate secret compartment
The door contains a 'kumiko' panel made in Yakusugi Cedar from Yakushima, Japan.
It's essential that the door is made absolutely, dead 100% square and true. Mine wasn't :eusa-violin: so I enlarged the gap (or error) with a small router bit and fitted a strip of Pink Ivory each side....very Alan Peters :eusa-whistle: The door rails sit 2mm below the 'kumiko' panel and the Pink Ivory inserts are 2mm higher. The door catch in African Blackwood is an improved version of the one Krenov used as it's both spring loaded and incorporates and upstand to limit the door travel. The door's hung using offset Brusso knife hinges.
All pulls are identical (hopefully) and turned from English Boxwood acquired from WH a couple of weeks ago.
The cabinet went up onto the wall this morning with no issues...
...and was promptly filled with stuff collected from our travels - Rob
