chippy1970
- Joined
- Oct 5, 2014
- Messages
- 147
- Reaction score
- 0
Like the idea of the sliding upper drawer Roger
Sent from my MotoE2(4G-LTE) using Tapatalk
Rod":3lmugfa3 said:Have you got a separate pantry because you don't seem to have much storage?
9fingers":2dy42z03 said:.......Maybe you could see if the equivalent works for you?.....
Andyp":2lml7pun said:..... I will never go back to bending over in order to get things in and out of an oven.
Rod":3hbyc1e2 said:Going back to the plaster Mike, will you be using Distemper to continue the "authentic" look or using modern emulsions?
Mike G":7tvc6yuj said:Rod":7tvc6yuj said:Going back to the plaster Mike, will you be using Distemper to continue the "authentic" look or using modern emulsions?
In the new part, no. I'll be using modern paints. In the old part, I haven't decided yet. Some of the plaster is in pretty poor order, and I have had conflicting advice as to whether it is possible to re-plaster with lime over the existing. If we can use lime, then I may well use an authentic paint. If we can't, I may well not. Note the caveats!!
9fingers":2mnjmm7o said:When SWMBO and I set up home in 1977 we had a £10 secondhand cooker. When I installed our current kitchen in 1985, the oven and hob pair cost about £800.
When I suggested an 80 fold improvement in meal quality, my comment did not seem to hit the right note somehow. :lol:
Mike G":p66l9tf2 said:...I am wanting to avoid MDF and contiboard entirely...
Wizard9999":1p3zt8en said:Mike G":1p3zt8en said:...I am wanting to avoid MDF and contiboard entirely...
Is there a particular practical reason Mike or do you just have a philosophical position on it?
Terry.
