Planeiron
Hello. I'm making a diminished stile door in well seasoned oak. This is being made almost entirely with handtools. The only machine I use is a bandsaw for ripping large stock. So the issue is, does anyone have practical experience and advice (and hopefully photos) for:
1. marking out the diminished still part and mating rail
2. cutting the diminished part of the stile with handtools (I'll remove bulk waste with the bandsaw and plan to finish the edge with a chisel run against a 90 degree guide but not sure this is the best way with what I've got.
I've read that some people use a template for the cut on the stile and mating rail piece, some a sliding bevel (not a massive fan) but where possible I like to use the actual pieces for markup (cut one part and use as a template for the other?). Anyway, how would you do it or how have you done it?
I've all the stuff squared and true and have marked and cut some of the through tenons including in the diminished area and these stiles are all still full width. The bottom part of the door will be grooved for a panel and the top rebated for panes. Any decorative moulding will be chiselled in after (no scribing over).
I've asked this question on a forum based in the US and it's been radio silence. Maybe diminished stiles are more this side of the Atlantic? I've Ellis' modern practical joinery and the authorless door making for carpenters and joiners but none the wiser. I remembered there was a chap on here that impressively made a diminished stile door on a workmate bench! Hoping someone might have somes tips.
