Right angle drill attachment
the bear
Surrey
Anyone have any specific recommendations for a right angle drill driver attachment for getting into confined spaces please? Can’t get enough torque with a stubby screwdriver and probably useful in the future too. Seems to be lots out there. Looking for one that isn’t made of cheese
Many thanks
Hi look at the Milwaukee installation driver kit , I have found it very handy over the years but not if you are driving large 4 inch screws, all the other stuff it is fine.
I have one that will fit my Festool drill and it's got me out of many a deep hole. Don't know though if it can be bought as a separate 'add on' - Rob
Edit - plenty to choose from online
Haha I thought someone would mention the festool. I think it’s part of the drill kit?
I don’t need to buy a new drill, festool Milwaukee or otherwise perfectly happy with my makitas
I have seen there are loads online but looking for an actual recommendation of one of them please
Many thanks
I also have the Festool version for my TXS drill and it's been so useful over the years.....
I'm pretty sure it doesn't fit any other make of drill though...!
There used to be an aftermarket one that was a shiny alluminium version and it just fitted into the chuck of your drill......nowhere near as compact though as the Festool or Milwaukee versions.
I decided it fell into the category or once in a blue moon use so not worth spending lots on. Mine's an unbranded Chinese version, and have only used a few times but has worked fine.
I’ve had a few of the angle attachments that fit into a chuck, they all work, well kind of….. Bought the Festool txs with angle drive and the difference is night and day.
Many thanks
I can't recommend any, but I may have one knocking about that I can lend you if you want? If you want one to keep for future then keep looking, but if you just want to get this job done then I can hunt out what I have (hopefully...). Let me know.
I bet your bank balance was as well !!
About 20 year’s ago I decided to only buy the best and generally that ment Festool.
Since then better paid work came in. Can’t prove it was down to Festool but their quality definitely helps with the finished job.
Also super easy to get all the systainers to and from site
Couple of months ago my big dewalt cross cut saw died and I bought a Kapex, it’s the first time in 40 years that I’ve used a crosscut that cut 100% perfect.
Mine came in the Festool TXS Set along with the drill.....I've had it about 5 years now and back then, the complete set with 3 chucks, 2 batteries and a charger was less than £200..... Not cheap @£75 on it's own currently, but the drill itself gets used practically every day as it's my go to drill driver for the majority of the time.👍
My Bosch 12V drill driver came with a right angle attachment as well as an offset one which is pretty handy. But if the space is too tight to get a decent grip with a stubby though you're probably going to struggle to get sufficient pressure to stop a drill slipping. Have you considered a mini ratchet?
https://www.wera-tools.co.uk/tools/tool-types/ratchets/zyklop-mini-ratchet
(for illustrative purposes, the Bahco version is just as functional and a sight cheaper)
I would not leave the workshop without this in my bag, and it rarely gets put away when I'm at the bench, pipe organs tending to be both congested and riddled with decades old screws. You'll thank yourself in future if you use some tallow or similar when you reassemble.
G
Thats very kind and much appreciated Mark. On this occasion I think by the time postage is paid and item delivered it'll be not much more to buy my own. But thank you.
GarF, hard to describe, but on this occasion I'm confident I'll be able to do what I need. Though I can see a mini ratchet would be very useful as well.
I have a noname one. It's OK as far as it goes, but it is difficult to apply any amount of pressure sideways. But it has got me out of a hole now and again.
I have an old 7v cordless Bosch 90 deg drill driver I bought when I was fitting kitchens it's excellent and still going very strong but wasn't cheap at the time. Makita did one and there are probably unbranded cheapos these days. I also have a couple you fit ito the end of a drill and I've never got on well with those.
If you want to get into very tight spaces a simple flat ratchet scredriver is the answer as you can put loads of pressure with one hand and ratchet with the other, they're cheap as well. I'll see if I can find them on line.
EDIT. Mine is like this one listed by AXI, simple all metal but there are other types which should work just as well.
I always think that the drill attachments that aren't actually fixed to the drill look like you would need 3 hands to use them.
I have the Festool versions, quick tip, you can use them with a normal hex socket screwdriver if needed, maybe obvious to some people but I only realised it a while ago :rolleyes:
I also have the eccentric/off set chuck and that comes out a lot, very useful.
I have a very similar DW one to Duke's. I am surprisingly pleased with it - it seems both well made and well designed.
If you use standard-length bits in it, only the business end projects - the rest of the bit is inside the head of the tool, giving it probably the absolute minimum rear projection.
From memory, the hex shaft is the same size as normal bits, meaning I could, in theory, use it with my small impact driver, although that would probably wreck the gears inside. But it will work with any cordless drill chuck.
To eject normal length bits, you do need a strong pin, or something like an jewellers'/electronics screwdriver, or a suitably sized nail. Otherwise there's nothing to grip on, and whilst that's something to remember to take to have in a pocket, the strong magnet also means you won't lose a bit at a crucial moment.
Mine came from either Amazon or Toolstation, and wasn't expensive.
Thanks all. I bought the Milwaukee version in the end as it was on offer. I've used it today and it did what I needed it to do.
