The dining table rebuild has reached the stage where I have zero knowledge so would be grateful for advice.
I will be making up an area of 1000mm x 730mm with planking, fitted into a rebate in the large timbers on each side.
I think 20 mm thick into a 10 mm rebate?
Width per timber can be whatever is suggested is best.
Which orientation is best? lengthwise or across?
How much movement will I get in either direction?
and how do I allow for that in the assembly?
Thank you muchly.
Thank you muchly.
