Yes another bathroom reno.
duke
Field, Ontario, Canada
Scott
By now most must be tired of my bathroom reno's with little woodworking other than jambs, casing and baseboards.
If anyone is interested I will post some pics with very limited dialog. If not I do understand.
A little backstory, clients hubby started this job three years ago, wow but I do understand he is a dairy farmer with a lot of responsibility with their farm.
His wife approached me as I was leaving the village variety store about 1.5 months ago. At first I didn't know who she was until she said that she liked the job I did for Chris. She could sense my vacant look as to who she was, ten seconds later I knew her name was Liseanne.
Sorry for the novel.
We have 2 bathrooms in need of renovation so this is certainly something I'm interested in
I like to see the renos. We should be doing our shower room in the next couple of years, so directly relevant, but I guess I just like a bit of home improvement in general and also seeing what people are up to. It’s a bit like a soap opera. Pics make it more vivid.
Barhrooms are just a PITA, everything seems to want to resist or get in the way. The way to approach them is to get the layout clearly defined and then sort out the largest pipework first, ie 4 inch soil and stack, then the 50mm from the shower ending up with the 40 and 32 mm waste. Personally the only plastic I use is the waste pipes, everything else is copper and I try to drop that down from above rather than horizontal through the studs which seem to be getting smaller.
I have had to put a push on this job as I am starting to get backed up .
Yeah, it can be a real problem doing bathrooms if the loo is out of action for a while ;)
You are in Canada, right ? Bathroom plumbing around the world varies so much in what is normal / according to code. Makes it interesting.
Always interesting to see how things work in different countries, many different approaches.
I start on an en-suite tomorrow, I plastered out the room a year ago & it the intervening time the layout plans have changed so I imagine I’m in for some fun :unsure:
Since we have a delay on the delivery of the vanity we are removing the textured ceiling in the family room. Along with new trim and wall and ceiling painting. Here is the owner removing the textured ceiling finish.3190.jpg3188.jpg
I hate popcorn ceilings. Impossible to repair unless you're a pro. I've stripped almost all of them out of my house. Good work!
And talk about the amount of dirt, dust and crap that gets stuck on it. This house was built in the mid 1990's, you don't see it much after this.
Thought this might amuse (or terrify!) those you bathroom renovating. It's a brand new stud wall, plasterboard one side, in my son's house. The now sacked builder claimed he needed to run the soil pipe from upstairs inside the wall, parallel to the 'cold feed'. I estimate there is 3-5mm wood left at the sides of the bigger holes in places. The builder knew there was a 16Kg air unit to be hung on the other side of the wall....
Is that chicken wire mesh I see?
Wonder why the builder couldn't surface mount the pipe then box it in.
I hope that isn't a load bearing wall.
Ian, I suggested Tim 'bridged' the holes with supplementary studs, length at least 50cm either side of the hole, glued and bolted through all three thicknesses.
He also told me of other horrors: a triple ply floor beam, underneath the eventual main kitchen 'island'....20mm off the load-bearing wall at each end. He sent me a video of him flapping a packer back-and-forth underneath one end.
One of his 'grey' water drains goes up over a floor joist, then comes back down again....need I go on?
Duke, yes, but what it is for I don't know. I'm sure Tim will be "liberating it into the skip" (dumpster). The wall isn't supporting the floor above..no, but it has a whopping 16Kg air unit to be hung on it..😕.
Tim is an engineer and is extremely finicky about loads and displacement. He has spent a month (of weekends and holidays) just "snagging" and fixing. I am of the opinion that his so-called "builders" so thoroughly resented his initial Snagging List, they deliberately worked each repair as a "F**k You" - a practice regrettably not unknown.
