Well winter is not far away and I need a posh cover for my outside tap.
Anyone got any suggestions or links?
It is currently 28 Mar 2024, 23:15
Doug wrote:Seen quite a few different ones over the years this style seems quite good, lots of different brands but basically the same.
https://www.toolstation.com/apollo-outs ... ver/p46836
Mike G wrote:Better if you can have an internal isolating valve. Close the valve then open the tap, and you are safe from a burst. If you need the tap at all in winter, then open the valve, use the tap, then close the valve and open the tap again.
