Looking at this cutter set
I think with some judicious fettling, removal of cutter bits and two passes (inverting between the passes) that it would be possible to have the roundover on both sides of the door. What does the team think ?
TIA
It is currently 29 Mar 2024, 07:15
Trevanion wrote:£83?! I'd sooner have a set of euro knives ground to my exact spec than pay that much for a pair of dinky router bits Roger. Especially if the router bits include faffing about, I can't abide faffing about!
Mike Jordan wrote:If you have a spindle moulder, eurocutters 98/99 may be suitable.
RogerS wrote:Fair point but that is for both cutters. I admit that I did blanch at the price.
Trevanion wrote:RogerS wrote:Fair point but that is for both cutters. I admit that I did blanch at the price.
Yes but what size door are you making? if under 25mm you could get both made onto a 55mm cutter or maybe even a 50mm, and if you don't have the limiters (you should really, but it wouldn't be the first time for you ) that won't cost as much as the dual bit set and you will get a much better finish, plus the less faffing.
Mike Jordan wrote:I thought that 98/99 were scribe and profile?
