- Joined
- Jul 21, 2014
- Messages
- 10,414
- Reaction score
- 165
Recent clearance of the kitchen for decoration revealed a lot of stored cr4p but also some that needed to be retained and there was a space under some wall mounted shelves for a 1 metre wide base cabinet.
Rest of the kitchen dates back to 1985 with Wickes units in oak where the finish has darkened to a fairly mid orangy brown which we don't particularly like but at the moment I cant raise the enthusiasm to make all new door and drawers.
So the cabinet needs to match as best I can for now. Fortunately there will not be a side to side comparison so near enough should be good enough.
This is the style of the existing. Rail and stile construction with bolection mouldings and and extra decorative panel surrounded by a similar moulding.
Although I have a reasonable selection of router cutters, I could not copy the moulding exactly but this is near enough to be acceptable.
Te starting stock was 17 x 21 mm and three passes with different cutters with combinations of feather boards etc kept it fairly safe but a bit hairy. Some snipe at the ends but I made several metres extra.
The basic cabinet is simple as are most kitchen cabinets. Stile and Rail end panels joined with face frame sections and stile and rail doors. The current units have drawers above the cupboards but I only wanted cupboards but kept the look of the drawers with an intermediate rail. Later on you will see a 4mm FTG kerf cut to keep the look of a drawer to all but a detailed inspection.
Rigidity against racking is provided by tight fitting bottom shelf of 16mm melamine coated chipboard and the back panels of 5mm ply I had lying around and painted white.
Infact everything was made from stock offcuts apart from the melamine chipboard. I've spared you pictures & description of all the stock preparation. All routine stuff.
The infill panels are ash veneered mdf 7mm overall and everthing else is oak and by the time it is stained, only the purists might spot it.
Currently posting this and trying to cook a roast dinner at the same time so more later! :lol:
