Time to tape up the pairs of leaves.
I find it best to use good quality masking tape that has a good stretch to it. I apply to one leaf, press down hard with a finger nail or even a roller and then stretching the tape as tight as I can, press it down on to the second leaf. Working from one end, I apply tape about every 200mm or so and then run a piece the full length of the join. This piece is more about keeping glue in the joint and does not have to be stretched taught just firmly pressed down.
Not much to photo but here is the stack of taped pairs
When vacuum veneering you need a flat platen the everything gets pulled down onto. These panels are going into a frame so will be held flat by that but assembly is much easier if the panels are flat to start with.
I'm using some 1/2" birch ply which get a sand all over and rounded edges to make sure there is no risk of snagging the bag/ plastic sheet.
The platen only needs to be a little larger than the biggest panel.
Just to make sure any glue does not stick the precious veneer onto the platen, I tape newspaper on the top surface.
I make my vacuum bag from builders polythene sheet from Screwfix/Toolsatan. Essentially the sheet is cheap enough to be disposable but I re-use it for a few jobs and only discard it if it get punctured.
You need a piece twice the size of the platen plus about 6" extra all round for the seal.
Check the surface all over for any odd blemishes that might lead to a leak. I put a patch of insulation tape on any such blemishes - they are pretty rare.
It's at this stage where preparation is vital to prevent issues occurring once the glue is applied.
Lay the polythene onto a clean bench, use a clamp or similar to keep the vacuum pipe from slipping out and wrap a small piece of toweling around the end of the pipe to help the air to get out.
You will need glue and an application roller. cooking grade PVA will be fine, I does not have to be D4 just what I tend to have handy.
The seal is made with silicone sealant - cheapo is fine. Prepare the gun, poke out the previous cured silicone from the nozzle and make sure you have a spare cartridge handy so you don't run out part way through (like I did today!!)
Finally fire up the vacuum pump. mine has a calor gas bottle to act as reservoir which helps pull the vacuum quickly.
Time to draw breath, lock up the dog, ban the wife from interrupting and take the phone off the hook. You need to work quickly and accurately.
