A bit of a frankenbox ….
Stuart
This box has been something like 6 years in the making for various reasons.
I fancied having a go at that Japanese Shuey McFee where you attack wood with a blow torch as I quite like the finish it gives. I had some bits of oak in the offcut box so I thought I’d give it a go!
It’s incredibly simple construction just mitred with the top rebated in. That was the easy bit.
Out with the napalm (well, a plumbers small blowtorch actually) and applied copious amounts of heat all over. Immediate disappointment as the joints opened wide and it looked awful. I shouldn’t have been surprised really with such heat application there was bound to be differential movement.
For some reason instead of binning it I threw it on a shelf and forgot about it.
A few weeks ago when having something of a clear out (or a move stuff around session to be more accurate!) I discovered it. The initial temptation was to throw it in the burning bin but a closer inspection revealed that all the joints had closed up as I suppose some form of equilibrium had been achieved.
I decided to attempt a conclusion but reapplication of heat was a non starter. The colour was unequal (not the deep black I was looking for) and it was very ‘charcoaly’ . It was therefore attacked with a wire brush but this didn’t make a lot of difference. I upped the stakes and used one of those wire brush wheels in the battery drill and managed to remove quite a lot of the charring but this in turn removed the colour even further. It did however provide what I felt was a really nice texture.
Something else I’d be wanting to try was ebonising so I whipped out some vinegar and threw in some nails and wire wool and waited. Nothing happened!
It transpires the nails and wire wool need to be rusty to produce anything usable for darkening oak. Anyhow, it worked eventually but I suspect that as the oak had been heated and hanging around for such a long time the tannin level was low so the level of ‘blackness’ isn’t as deep as I’d like.
A small oak plinth added to provide a bit of contrast.
After all that I still gave very serious consideration to throwing it in the log burner but was persuaded to at least apply some finish. A few coats of shellac and some wax have darkened it some more but I still don’t know if I’ll keep it.
Never have so many treatments been applied to one small box. Here endeth the saga.
Wow. Very unusual. Keep it. Though it looks like you rescued it from the log burner :lol:
I do like the effect.
But that looks lovely!
If you hadn't told us the story, I would have thought it was bog oak.
I've had plenty of experiences like that in the past, and many have ended up in the fire!
It's a very nice box, the texture and colour adds a lot of depth to it and it almost looks like an antique from the old world.
I’m surprised, in that I didn’t think I would like the "rough" finish, but that’s really quite nice.
From my limited and not very successful ebonising, dark blue was the darkest it would go!
The wire wool has to be washed in washing up liquid to remove the wax then with the nails etc it needs a bit of a boil up in the vinegar, pickling is best — but I’m sure somebody more successful than me will be along in a minute to advise lol.
That looks really good.
I had a go at ebonising a while ago. I just chucked some fine wire wool into a Kilner jar and poured white vinegar over it. I then left it for a month or two until the wire wool was gone and the mix was a grotty rusty colour. After filtering it through a coffee filter, it turned the oak a very dark blue colour. I'd been hoping for a proper black, but no such joy.
That looks fantastic to me! I really LOVE that texture from the wire wheel and the colour is lovely! I'll be logging that away in the memory as one to try in the future!
:eusa-clap: :obscene-drinkingcheers:
That looks fantastic, I tried a similar technique with a fountain pen and cufflinks/cufflink box both made from oak (the pen used oak from a section of a Charles Rennie Macintosh chair which survived the fire in the Glasgow School of Art).
The grain was filled with a silver embelishing paste.
Giles at Tickledown is extremely helpful and the kits are first class. He's happy to talk you through what he has on the phone and has thrown in some additional packaging and boxes when i got razor kits from him.
Without wishing to hijack this thread, I'll start another in the Turning Section - Rob
I love the texture of the box, almost looks like wenge burnt, and a bit like fumed white oak as well.
