Trevanion
I've been rebuilding a Europa 340 power feeder unit for a while now intermittently and I had totally rebuilt the gubbins, new bearings, new wheel cover, changed the gearing ratio to facilitate a slower feed speed, and I'd even painted it all! In all I've probably spent £80 in parts, let alone hours spent!
Between taking apart and putting it back together it had been about a year and a half, and all the parts were just jumbled in a Celebrations tub. When re-attaching the motor, because I had no real clue what went back in, I used the incorrect screws to attach the motor via the flange to the feed unit itself, 25mm in length instead of 15mm! The screw born against the windings inside the motor and when I attempted to start it up it just blew fuses, at this point I didn't know what was wrong until I got a multimeter and found that the windings were all earthed. I had effectively turned my electric motor into an arc welder.
I just brought it back from the local rewinder, who quoted a cool £500 to rewind it (realistically a whole new feeder is ~£700). A new motor supposedly cannot be sourced/adapted because of the unique slotted shaft end and unique flange with seal.
My options as of right now are to try and find an identical new motor, which will be difficult and my first port of call would be CEG/Orange1 Motors who originally made it. Or, to have a crack at rewinding it myself, which will be nigh on impossible given my lack of magic electricity skills, but possibly given enough time and research it could be done.
So yeah, make sure you catalogue your parts properly so you don't end up like me! :lol:
