A little project today
Lons
Northumberland
The temperature finally crept above freezing in the workshop so knocked this out before settling down to watch the football. A couple of hours was as much as my cold hands could cope with so I glued it up in the house.
Not an essential tool but one I've wanted to make for a while. In the rough style of a plane knob but a bit bigger it's from a piece of walnut just waxed finish, the brass parts turned on my little lathe and the screwdriver blade ground from an ancient flat drill bit. Works a treat.
What stops the blade from rotating?
The flat part of the blade, think old flat bit, is sunk into a slot I cut in the handle and the whole blade is fixed with Araldite so hopefully that's enough Mike. If not then it's a prototype. ;)
The easiest way to make one is to use an old original plane knob but I had nothing suitable
