In the manky cellar is our water treatment plant...
and a simplified diagram
Beneath the pressure vessel is a pump (you can just about see it in this photo)
So water comes in from the borehole - left of diagram - into the drop tanks and there is the pump and pressure vessel that takes water from the drop tanks and pumps it through the iron/manganese filter into the 'clean' water tanks. There is what looks to be a float switch on the 'clean' water tank that is triggered when we draw off clean water up into the house. The float switch seems to be a vertical tube going down in the water and I'm guessing (it's hard to see) that there is some sort of float with a magnet that triggers the switch...no idea what the technical term for such a switch is.
The thing is that this pump seems to keep kicking in throughout the day but doesn't run for very long then there is an audible ker-thump when it switches off. And it's annoying as you can here it in the house. The pressure vessel is supposed to damp this out and as far as I can see (there is a pressure reading on the meter attached to the pump) is pumped up.
So I was thinking about having two level sensors so that I could draw off a reasonable amount of water before the pump kicks in and does a longer refill.
Very much like the heat store control in another thread.
Can anyone see any disadvantages ? Haven't quite got my head round the type of float switch/whatever yet and so any pointers appreciated.
