Steve Maskery
Oh yes, the French are World Champions at bureaucratificationising.
"Feathered maidens" ? One is a 'semi-dwarf bush' ?I've just planted a few fruit trees as feathered maidens. One is a fan, two are cordon's and the last is a semi-dwarf bush. The supplier's own website was a wealth of information as was the RHS's.
I said the supplier's website was a wealth of information. You didn't digest my post, you naughty boy!"Feathered maidens" ? One is a 'semi-dwarf bush' ?You've been watching 'those' channels again, you naughty boy View attachment 31473
Dicotyledons.Leaf pairs
Rude!Dicotyledons.
'Found'...I don’t know anyone who needed a few beech saplings to complete a small hedge around his composts bins so went into the local forest and dug up a few . They are now at the required hedge height of about 5’ and he can’t tell the difference between the bought ones and those he found.
Sounds quite good to me!Make sure you contain the roots if it's blackthorn or you'll have a field full of blackthorn before too long.
The oaks I planted were the same size 5 seasons ago. They are 10 feet tall nowI'm going to collect the new oaks tomorrow.
"Do I need to bring a trailer?"
"No, they are inches tall, not feet, they are all in a bucket".
This might be an even longer project than I anticipated! Apparently oaks have a massive tap root, so even small trees need machinery to dig them out intact. I didn't know that. But at least seedlings are more likely to take to a new home than an established sapling, I guess.
Watch this space!
Well mybe, one day, but not in my lifetime, I suspect.forêt is better View attachment 32005
That is very encouraging, thank you. It's possible, but by no means a given, that I shall make it to see the same. I hope so.The oaks I planted were the same size 5 seasons ago. They are 10 feet tall now
I'm sorry to disappoint you Steve but that's not going to happen. Try as you might, I can confidently state you will NEVER reach 10 feet tall!That is very encouraging, thank you. It's possible, but by no means a given, that I shall make it to see the same. I hope so.
The biggest cause of loss for me was voles eating the bark around the bottom of the trees. The next was the trees getting mangled in the tree guards. If Deer are a risk then guards would be worth it but the solid guards are homes for voles and the mesh ones mangled trees when they grow through the mesh. It all means you need to check the guards regularly.I'm told that the rabbits are extinct due to hunting There are deer in the woods a little way away, but we've never seen them round here. I know it wouldn't be a bad idea.
Yes mulch is good to keep the grass and weeds down local to the tree roots. Gardeners do not like wood shavings or sawdust because of the ph. However the tallest and healthiest tree in my plantation by a long way was planted where I used to have my annual hedge pruning fire. Just saying. Of course it could be coincidence but…Jeff has suggested I mulch the trees with sawdust, I probably have enough, in bags. Mainly oak and chestnut, a bit of softwood. Is that a good idea, do you think? It's all fresh stuff, not aged and mature. I'm wondering if anything nasty will leech out of it.
Any guidance gratefully received.
