Windows
I have a vague idea that at some point in the next decade I might like to make a couple of brass escutcheons (for room doors) to echo a design from a fireplace. The design would be kind of a Nouveau style with a couple of raised dimples and swoopy edges - simplified for the escutcheon, so it won’t end up super complicated.
I thought I’d start a thread so that anyone with brass working experience, opinions about escutcheons, or links to existing escutcheons could drop whatever info they considered appropriate here.
I imagine the process would be something like:
1. Get flat stock of appropriate thickness
2. Mark screw holes, key hole, dimples, and outline
3. Drill screw holes
4. Chamfer screw holes (how? using a countersink bit?)
4. Drill key hole roughly (or drill and saw?)
5. File key hole precisely
6. Make a dimple press (screw clamp?)
7. Use dimple press to make dimples
8. Cut outline roughly (hand saw?)
9. File outline precisely
Does that sound about right? What bits, saw blades to use for brass? Maybe dimples need to be added before everything else marked up?
