Cake Stand
Woodford Green
I'm not Bob
Our best friends daughter is getting married next month. She is a creative type and is planning a DIY reception. I got asked to make a stand for the wedding cakes. Something like this - a picture of some perspex creation that looked like it would break if you leaned on it... but I want it white.
She eventually gave me the size of all 5 cakes and it added up to about 750mm tall for the top tier.
Knowing she would appreciate recycling i tried to use what was laying around the workshop. Some Ikea MFC cabinet sides had to do as I didn't have much 18mm MDF.
Cut some squares and marked the middle and drilled 2.5mm and left the bit in with 6mm sticking out.
Next problem was how to bandsaw circles. It soon dawned on me a simple peg and hole wouldn't work as you couldn't get it on the peg to start the cut. So I made a pivoting board with holes drilled for the centre peg at the required radii.
So I could fit the peg then swing the arm in to start the cut.
Now around here there are some pictures missing. I wanted a profile on the edges. I had one piece of MDF around so I cut it to the largest circle for testing plus it would help working out spacings.
I put a large table top edging bit in the router table cutter and tried it on a scrap strip - looked good. The bit was 80% inside the fence so I thought I'd try the MDF circle. Hands were well away from the cutter but of course the first touch snatched...which I thought I was ready for. Normally it would just kick to the side. This being a circle it span on the spot. Still don't understand how my left hand got to the cutter but it did.
2 fingers cut but could have been so much worse.
This is a few days later once no plasters needed.
Anyway I went with a simple radius cut on the edges after that.
Chipboard having an edge that is full of holes I wiped it with cellulose sealer mixed with polyfilla powder.
Then I needed some poles. Best I could find for large dowel rod was some tree stakes at b+q. I tried sealing and sanding but they were too rough.
Cut to length then sanded on the wood lathe that I have not used for a year or so.
Drilled the rod ends and fitted those wood thread to machine thread things you see on table legs on flat pack furniture. Hammered Tee nuts into the cake platforms.
Time for a test assemble.
Sprayed with Bedec MSP paint
Some overspray got on Mrs pot plants so I'm currently in her bad books.
Used the MDF disc as a painting mount for the rods. You can see where it snatched.
Ready to go.
Nice work, apart from the fingers, red and white never look good!
If the cakes are as good as the cakes my nan used to make, then it'll be great!
Nice idea. I like the pivot solution to cutting the disk on the band saw. Ingenious. Big wake up call with profile routing the edge of the disk. I've done it several times and got away with it, but could have been very different. Glad you didn't suffer serious injury!
Are they going for proper cakes or ones like pork pies or cheese??
Glad your injuries are on the mend.
Steve Maskery has a circle cutting jig which I made a few years ago - trouble is I have to think really hard how to use it [emoji3]
All I was given were overall sizes of the cakes - 1 at 11"dia... 2 at 9.5"....2 at 7". Heights were a bit vague - allow 6" for the big one and 5" for the others. Needed the heights as they overlap. All the discs are about 1 1/2" oversize on diameter.
Made a change from drawer boxes for my 'office' furniture (which I will get round to posting).
Wedding is about 3 weeks away . obviously I'll be taking pictures.
The reception venue was an ex church in Liverpool now known as the Black E. It's the building to the left of the Chinatown arch.
We were in Liverpool for 4 days to help with setting up for this part DIY wedding. Months had been spent folding near on 3000 origami cranes from squares cut from A4 coloured and white paper. The coloured ones are sewn with fishing line and suspended from hula hoops. I tied all the suspensions and went up the ladder to hang them so if anything came down it was my fault. Fortunately all stayed put.
The white ones were on all stairways etc to kind of indicate which stairways were in use.
This is soon after hanging and positioning over the tables. The main lights are on so no atmosphere.
You'll have to imagine the room with the tables dressed as I can't post all the guest pictures.
I will post one of April and Rob though..
April is Vegan and this was a Vegan wedding. All those cakes are Vegan and all the (Indian) food was Vegan.
It was all tasty and everyone had a great time. I'm back to being an omnivore now :)
