Yes, tapping them down is good enough for testing the fit, but when it comes to fitting the crest rail and then gluing them in, it really needs to be clamped.Very interesting, Nick. I'm unsure as to why you needed that fancy clamping arrangement. Could you not just tap the (free) top end of the bars with a mallet/ rubber hammer?
I think I've done it all with a flat soled Stanley (a 151??). None of the curves are tight enough to need the round soled version. I only needed to grab the round bottomed one because to use the blade in it having worn out the one in the flat soled version! The worn out blade was new to me a few years ago and I'd extended the holes once to try to get a bit more out of it.Ditto!
I'd have been tempted to try out quite a few different spokeshaves if I was attempting anything like your chairs - but I expect you have taken a rigorous approach of sticking to one good one. What's your tool of choice for all this lovely hand shaping?
Not that tempted now I know this method works. Doing it by myself, I worry the glue will lock everything up before all the back bar joints are all pulled up. It takes a bit of time to assemble the clamping arrangement. I'm not in a hurry and, in any case, I can get on with other things between each gluing phase.Are you not tempted to glue the legs on at the same time as gluing the rails to the bars?
Thanks Mike. I hadn't thought of that. I'll give that a try on a practice piece.I think hot-melt glue is your answer, Nick. It gets a really good hold, but is relatively easily removed afterwards by prying, or you could re-heat. I would definitely, definitely have the cutter in a router table as this would prevent any suggestion of tipping the router, and you could get a good grip with both hands well clear of the cutter. Obviously this means a shallow cutter with the follower-bearing at the base. Someone linked to some like this a few months ago, and I have one. It works well.
The one variable with hot glue is its thickness, which would mean your depth of rebate could vary somewhat. This might mean doing the bulk of the work with the template, but the final pass after it's been removed. If you're not used to hot-melt glue, it cools very quickly. Your open time is seconds, so you need your ducks in a row when you start the job, or you need to warm your timber to slow things down a bit.
That's a great tip. ThanksI'll agree with Mike, unsurprisingly, and add that to address the against-the-grain problems you can do your initial waste removal down to depth with masking tape wrapped around the guide bearing. That will take you a fraction away from the final line, and then when you remove the tape you'll have a tiny amount of material to remove in the last pass. That's often enough to get a decent surface finish even when the grain isn't co-operating.
Thanks. I've tried that before and found it too strong. It was too hard to get it off!I have used a good two way carpet tape for a few templates and used my router table.
Thanks. Some good food for thought there.I do a bit of template work with routers and also the spindle moulder, but with regards routing, and I don't know if this would work in your circumstances, I make my templates in an L shape form by fixing another piece to the templates back edge, I then use clamps across the faces leaving the template top face clear for the router to run along, I also attach a wider base to the router, usually a piece of Perspex, which gives more support to the router base, rather than it tottering un supported.
With regards router cutters and cutting, I have 2 methods, 1: using the same diameter bearing cutters but in different lengths in order to give me the increase in the cutting depth incrementally, rather than taking too much off at one time but this method does mean swapping cutters out as I progress to a deeper cut, but you get to a point that the next cutter length will reference off the previous pass, so the template is no longer required, or 2: using a guide bush, and a straight cutter, and adjusting the plunge depth, but this does mean the template has to be made to account for the offset, and be used until the finished depth is achieved, my preference is method 1 as I find it more accurate to make the template in the first place.
I have also tried and used sticky stuff as an option but found it to be a bit of a lottery, more so if you need to replicate fairly close positioning on multiple items, and then the faff of cleaning up after, that's why I generally try to use an L shape type template as it always back references of a face.
I don't know! The prototype seemed OK so hopefully they'll be alright!Most impressive, are they comfortable?
Well there's definitely a gap but it's certainly not the worst joint I've ever done either!If that's what you call a gappy joint, you're not allowed to visit my house![]()
Thanks Mike. I'll see how this one goes with the router. It should be easy enough once I've made the template and found a way of clamping it on securely, but I'll consider other options if it doesn't go well. Fingers crossed...Great stuff Nick. Yeah...clamping curved tapering stuff whilst banging in wedges: great fun!
I wonder if for the next chair you might find a way of doing the shoulders of the seat rebate in the front legs prior to assembly. You're left with a tricky router job now, but if you had got the shoulders sawn, it would be a very quick and easy job with a gouge.
