For some time now I've been thinking about making myself a new desk for the computer and all the stuff that goes with it.
Currently I have a cut down office desk saved from back when I had a business. The room I'm typing this in is a small box room bedroom so the desk is cut to 2 foot front to back. The cutting made it a bit less stable than it was but it is OK. I have 2 monitors on arms from a lump of wood screwed to the back of the desktop and extending down to the floor - I didn't want to drill the wall.
What it can't cope with is all the wires.
I also kept 2 pedestal units and a side table. The pedestals are solid but have 2 drawers that are too shallow for my camera kit etc and one deep file hanging drawer that is too deep.
The most annoying thing about them is the stupid drawer slides that only open half way.
Heres my sketchup of the revised furniture. I've since decided not to enclose the printer and have 2 identical pedestals as before. The side table becomes a wide pedestal also with castors.
Top of the desk with various bits hidden to show the cable route at the top and sides
The desktop will lift off for access to another cross route for cables
So this was the oak flooring I bought.
I wasn't sure what it would be like to work with so i thought I'd start with the simpler stuff.
I want it all to look good when it is finished but it is about practical more than fine woodworking so I'm not going to be making things you can't see pretty.
Damn my planer is noisy. Doors shut to keep the noise in, ear defenders on. Afterwards Mrs still complaining I'm making too much noise. The planer didn't seem to like doing 200mm wide oak too much either. lots of vibration and adjusters revolving on their own instead of staying set. Anyway ended up with a set of parts for the pedestal carcases.
I cut off the tongues and got rid of any remaining edge bevel then grooved the edges larger than the existing groove and cut loose tongues.
Clamp up
Quick run over with the sander
There are anti curl grooves on the back which would spoil things going together so they had to come off. Thinking in terms of resawing I screwed a metal strip to the router fence then ran the panels through to get a constant thickness with no grooves left.
Not perfect on the corner but close enough to easily fix
Tryout
held together with pocket holes and drywall screws. i'll not pay out for special kreg screws!
One of the standard pedestals put together as well
That's as far as I've got. Need to get some ply for the backs and drawer bases.
Still thinking about how to go about the desk. May change the end panels too. Be some time until I get to the desk itself.
Clamp up
Tryout
