Back in 2018 I purchased a load of very green, very heavy London Plane which I seasoned and although much of it cracked there was enough to make this JK style, wall hung cabinet. One particular board had a very unusual 'flame' pattern running through it and I've used the most pronounced part of it in the back panel:
Interior showing the 'flame' pattern back panel, drawers and hand planed, concave door:
Couple of drawers; 6mm quarter sawn oak sides and bottom, London Plane front with through dovetails. Indian Ebony turned pulls:
Carved door pull:
Cabinet back; held onto the wall using the 'French Cleat' system which is very effective:
Carcass construction was done by using ply inserts, slots machined on the router table; much, much easier than using a Domino. The carcass was also lipped and veneered over a pine core; finished with four thin coats of MMM, followed by a goodly application of Swedish organinc beeswax from CHT.
London Plane isn't my most favourite timber as I've found it quite soft and 'woolly', so I'm glad to see the back of it, though I do have one or two chunks of quite spectacular London Plane 'Lacewood' which might get used for another project later on - Rob
Carved door pull:
