droogs":3n8q7jxs said:@Peri, Did you make the jig on a CNC or by drilling and then stamping in the sizes. Just had an idea when I saw your plate that If on the CNC; you could first drill some 1/2 mm holes around the circumference before drilling out the main hole and get glue channels incorporated to the plate.
Pete Maddex":3obnfxi2 said:G&S timber do dowling
https://www.toolsandtimber.co.uk/hardwo ... den-dowels
I have used them my self and they are very good.
Sorry I didn’t connect tools and timber with g&s timber.RogerS":3qd89e6z said:Pete Maddex":3qd89e6z said:G&S timber do dowling
There's an echo in here![]()
Peri":25vjf5jz said:To be honest, I've never had the greatest of luck hammering bits of wood through them (others have though) - maybe my technique is a bit iffy, but thin dowels splinter and big dowels don't stay straight. I do mine with the 'drill' method, and that gives great results.
It's a good idea though, and wouldn't be that hard to do
EDIT: One problem - for best results I've found gradually reducing the dowel in size by making a few passes through consecutively smaller holes is the best method. If using glue channels you'd need to do the whole job in one pass, not sure how well that would go. Softwood maybe ok, hardwoods, maybe not.
Pete Maddex":2be8esd0 said:Sorry I didn’t connect tools and timber with g&s timber.RogerS":2be8esd0 said:Pete Maddex":2be8esd0 said:G&S timber do dowling
Still two recommendations they must be good.
