I'm in the process of making my first box and trying to restrict myself to only using hand tools. I'm not too worried if it ends up looking awful and I don't really care what size it is, I'm mainly just doing it for technique practice.
Having said that, one part of this afternoon's activities ended up being a bit very frustrating! I ripped a bit of oak in half, planed the two faces of each half and then clamped them together in the vice with one edge up. I then planed the edge of both pieces together. It took me quite a few goes before I was happy that the edge was exactly at right-angles to the faces and I wasn't really sure what I was doing, but overall I was happy up to this point.
I then turned the two pieces over and tried to plane the opposite edge such that it was at right angles to the faces and such that measurements of the width of the board at the two ends were the same. This did not go well. I've watched a few youtube videos (mostly Paul Sellers ones), but I'm clearly missing something. I'm holding the plane with my left-hand gripping the sole (rather than the knob) and with my fingers against the face of the board. I've tried it with my left hand on the knob as well but the results were much the same.
I'm guessing my problem is that I put too much pressure down on the start of the cut and not enough at the end and also that I put more pressure down on the left-hand side of the plane than the right. I'd spend ages getting it such that the two end measurements were the same and find that it was a long way off a right angle (always the same way with a higher right-hand edge as viewed from where I stand for planing).
I'd then spend ages getting it back to a right angle, by which point the near end was about 2 mm narrower than the far end!
That went on for a while. I got there eventually (having taken the board width down from 100 mm to 75 mm!), but at the end I didn't really feel like I had learnt what I was doing wrong. It feels like a real struggle to adjust an edge angle (to get a right angle) and also very hard to maintain an edge parallel as it gets planed.
Can anyone offer me some advice on what to try to get a bit better at this?
