Cabinetman
- Joined
- Oct 11, 2020
- Messages
- 5,272
- Reaction score
- 1,026
- Location
- Lincolnshire Wolds + Massachusetts
- Name
- Ian
So I picked up a D/X mobile unit and it works just great for what I will use it for - single mc at a time, it came with a flexible hose that has a copper multi strand wire running through it fastened to the tin duct connectors. Fairly obviously the wire has to be long enough for when the hose is stretched and this means that when it isn’t the wire flaps about inside and is causing blockages with planer shavings.
Now I have never earthed my flexible hoses in the past and I’ve never had a problem with explosions lol, am I being Blasé ?
Are you meant to expose the wire in the construction of the hose where it touches the tin duct ends? But then the wire is insulated from the dust in the hose. Confused.
What do you all do? Earthing wire or not, anyone ever had a problem without?
