Some years ago I made a Krenov style cabinet in Elm for SWIMBO's collection of fossils and my daughter 'oop narth' in Carlisle recently requested something similar from the WoD in a dark brown wood. I gave her the option of either English Walnut or Brown Oak and she opted for the latter.
I had just enough from some boards purchased at Yandles two or three years ago and for the design I went for something pretty straight forward...
Nothing too fancy here with no curves, but I did go for my usual through mortice n'tenons on the stand which were then wedged with Bog Oak, left proud and then rounded over; a proper 'pita' to do but quite effective once complete:
As with most of these JK cabinets, the stand is separate and in this one, the display case just drops into a recess at each corner of the legs:
The door is pretty standard with some Brusso knife hinges from CHT to hang it and a shadow gap of around .6mm (the thickness of a bit of veneer). I used a traditional JK sprung door catch and used on oddment of Bog Oak to carve a handle:
I had just enough Brown Oak to make a twin panelled back which was glued into a small rebate in the case:
The display case itself is made from MRmdf, veneered over the top with 2mm thick Brown Oak Veneers. Dominos were used for the side frame construction and 6mm ply tongues were used to join the frames to the top and bottom.
This is as far as I'm able to go with this project, bearing in mind the current restrictions, so it looks like the display case glazing and six ground and polished glass shelves may have to wait for another day. I'll give the glass people a tinkle on the dog n'bone tomorrow to see what the situation is, but I'm not hopeful.
Finished with a few coats of satin Osmo and a goodly application of CHT organic Swedish wax applied with a grey Webrax pad, then buffed with a soft cloth - Rob
