After distractions various - too tedious to mention, the fruit cage construction is now complete.
Firstly the sliding door. No construction photos I'm afraid but is is simple half lap joints screwed and glued. No need for any diagonal bracing as it is suspended from its top edge.
Here is the track in place with a timber cover for neatness and no other reason really. I had some pressure treated wood left over from the gravel boards.
A view from the outside with it closed showing a vertical board on the frame to keep it from swinging in any breeze.
Closer views shut and ajar from the inside.
I decided against any guides or restraints at the bottom of the door as I reckoned these were not really needed and could get clogged with soil over time.
The top netting is a woven mesh about 6mm square sold as hail protection netting. I seems very strong as is declared to be UV resistant - time will tell! internal head room is about 2.2m so room for tool handles etc.
There is a support matrix of steel wires at 900mm nominal pitch. Not sure how visible these are in the following photos.
Looking from the inside
and a couple taken standing on a step ladder from the outside.
The net was roughly attached using f clamps to start with and then aligned more carefully using the grid of the mesh. Then one edge was attached using 38x19 pressure treated tiling batten and stainless screws at about 300mm pitch. Next the opposite was tensioned and fixed the the same manner.
the long edges were then tensioned and the battens fixed to the fascia boards of the two buildings.
I was please to see that I could get all the ripples out by this method which would have been an eyesore (to me at least) when viewed from a distance eg my bedroom window.
All we want now is some fruit to start growing. Some strawberry flowers have started to appear and the raspberry blossom is in bud as are the red, black and white currants. The automatic watering is now on too to maximise the yield.
Now the birds will have to sit on the outside and stay hungry.
I've noted one or two comments about other building similar cages so these were the key suppliers I used.
All the timber and metposts came from In Excess - several branches of this "surplus store" in the south
http://www.in-excess.com/
The galvanised steel mesh was from
http://www.hillsofdevon.co.uk/
The woven hail netting came from
http://www.nutleyskitchengardens.co.uk/
Thanks for reading.
