Mike G":ug9mjx6i said:Are these timber feather-edge boards?
If so, then butt jointed is better than bevelled, and it is perfectly OK to install them with the ends still wet with paint. For a Rolls Royce job, cut a bit of 6" DPC say 3 inches wide and staple it (at its top edge) at the join location such that the bottom of it is just above the level of the boards which will cover it. Joins should of course be at a batten, which is why you use 50mm battens rather than 38. Don't forget to paint all round with a couple of coats before fixing in place, and then a final coat once in situ.
Cheers for confirming Mike. Yep, they're Larch feather-edge. Good idea about the DPC, I have some knocking around so will do that.
Am I reading your last sentence right? I should paint each board on all sides twice (presumably 2 coats of primer) before putting them up? Is this to avoid warping?
