Is a balancing veneer always required
Tinman
I have always used a balancing veneer on the reverse side when veneering large panels where I usually use birch ply or mrmdf as the core but I am wondering if it is always necessary to use the balancer particularly where it wont be seen
Small panels where the panel is glued into a frame all round
False drawer fronts where the false front is securely fastened to a solid drawer box
Dovetailed drawers where the front is a solid lapped dovetail construction with a decorative burr veneer applied after construction
Larger fully jointed solid carcases with a decorative burr veneer applied to the outside
Smaller boxes. My current approach is to veneer the material on both sides and then cut and join at the corners
As far as I know balancing mainly serves 2 purposes: aesthetics and equalising ingress/egress of moisture. The last is taken care of by making sure both sides are treated with the same product to prevent warping. The first is up to your tastes and/or wallet. The only exception to that rule I have ever encountered in my own practise (as far as I recall at the moment, I might overlook something though) was to balance weight when I glued sheet metal to a sheet of ply.
I once made a chest of drawers in maple, with maple drawer-fronts veneered with figured maple. I didn't use a balance and I didn't have any problems.
Veneer on MDF might be different, of course.
I wish you wouldn’t keep posting these photos of absolutely superbly made craftsmanship. They are truly gorgeous, Steve
Looking at old drawers with veneered fronts, I'm pretty sure they don't have a veneer on the inside.
My guess is that a well made drawer box is unlikely to warp?
What makes the substate warp (of whatever sort) is water; most glues these days contain the stuff. Old drawer fronts etc were hot veneered with hide glue which doesn't contain water; aka no warpage.
Much of my stuff is veneered with 2mm thick bandsaw veneers glued with a PVA of some denomination (Everbuild D4, Titebond 111 etc etc) and unless both sides are veneered at the same time, one face will bow like a banana - Rob
Edit- if you glue veneer with a proper two part resin adhesive (not UF as it contains water) the substrate won't warp either
Ehm, have I missed something?
In more than 2 decades of woodworking I haver never noticed that the moisture from glue has enough of an influence to cause any noticeable warping. I would think it would be gone too quick for it to penetrate deep enough to do that. But I use plain old white glue in almost all projects. Only in rare cases do I need anything else. I have used cascamite for jobs needing very long open times. In a few cases something else, depending on the job. I also use just enough glue to see a nice even line of minute beads coming from the glue line. Maybe that's the reason?
Normally no, but I'm discussing veneering where there are usually large surface areas of glue (hence water) in contact with the wood. Under those conditions, warping will definitely take place if only one side is veneered - Rob
  • Like
Reactions: HdV
My understanding was it was about balancing out the layers and the differential expansion along and across the grain which is why plywood always has a symmetrical pattern of plies. Agree that getting everything wet will exagerate the effect The question is more about constructions which are fully restrained by strong joints. As said by NickM most old drawers are veneered on the front only
I'm confused by this Rob, hide glue most definitely does contain water.
I asked Google AI why hot hide glue doesn't warp the wood and I quote:
  • Does not cause wood fibers to swell: Hide glue introduces minimal moisture to the wood compared to modern PVA (polyvinyl acetate) glues. This is because it is applied hot and in a thin layer, and its water content evaporates relatively quickly during the application process (especially when using traditional techniques like hammer veneering with an iron). Since the wood fibers do not absorb as much water, they do not swell, which is the primary cause of warping.
  • Minimal shrinkage on drying: Unlike other water-based adhesives that tend to shrink as the water content evaporates, hot hide glue does not shrink significantly when it dries. This stability in the glue line prevents the build-up of internal stresses that can pull on the veneer and substrate, thus preventing the assembly from warping.
Ain't AI wonderful? - Rob
from my own limited experience, hot hide glue is really good for veneering, there is no creep at all either but you have to cover both sides with glue and use a veneer hammer and work very fast and also heat up the surfaces well before glue up, I tried it out on a guitar headstock and it worked incredibly well, also no need for any kind of clamps and it cleans up with water.
AI in my experience ain't wonderful as a source of woodworking knowledge: I've tested it from time to time and it quite often talks gibberish in this field and I suspect that's because it tends to pick up the verbal diarrhoea of limited knowledge or wrong knowledged woodworkers, both amateur and professional. There are plenty of examples of one sided veneering, i.e., veneered panels lacking a balancing veneer. Hammer veneering with hide glue certainly can add significant water to the wood of which I have experience as can caul veneering where both the ground and the veneer (which is usually thicker, e.g., 1 - 2 mm) are heated prior to gluing up and pressing. Antique decoratively veneered drawer fronts are a common example of one sided veneering as already mentioned and I have repaired the broken sabre legs of numerous tilt top, sofa, and similar tables, primarily from the Regency period veneered on just one face. I have similarly restored or repaired quite a few items of cabinet furniture in which panels were veneered on just one face, and where this occurred on table tops they were frequently hollow sometimes requiring flattening with various tricks.
I refer you to Antique or Fake (1984) by Charles H Hayward, page 203 in my copy and who knew a thing or two about old furniture. "With the exception of flush doors used in many walnut presses and writing cabinets of the walnut period, nearly all period furniture was veneered on one side only. This did not matter a great deal for carcase work and for drawer fronts which were largely held flat by other structural parts, but it will often be found that table tops have pulled hollow, and this can be disastrous on pivoted leaves which have no means of stiffening."
Of course, it has to be remembered that all that veneer Hayward was whanging on about was applied to solid wood panels. Today, most veneer is applied to man-made board and, given that, I'd say that in most cases veneering on both faces is probably sensible especially as it's so easy and quick with guillotines, stitchers, and heated presses of various types, e.g., hydraulic and bag types, etc to handle the modern 0.6 mm thick veneers, i.e., traditionally peeled leaves and engineered stuff.
Enough from me, I think. Slainte.
Now that's just mean (following on the theme of sans-serif misinterpretation)
Sorry AI, or AI if you prefer. Maybe we could rename AI (AI) as AyeEye so as to avoid inadvertantly being mean to you? Slainte.
In the manufacturing industry, the large panels being veneered (9' x 6' or 8' x 4') would have a face veneer on top and a cheaper backer at the bottom. The 8'x4' would be for doors/cupboards and would have a face veneer on both sides.
Substrate of PB and MDF generally 18mm thick.
A PVA glue is used.
The combination goes into a heated press.
No backer = warp.
The thinner the substrate the greater the danger of warping.
Okume or Pine made good backers (cheap).
I have a stock of 200mmx200mm veneer samples and always veneer both sides of what I am going to make.
If you want to see really good warp, glue 2 pieces together cross grain. Even clamped not flat!
On drawer fronts, veneer is usually applied with the grain running the same direction as the backing board. In that case, no balancing veneer is needed. (just as no balancing layer is needed in any other kind of lamination with grain aligned). A balancing sheet is necessary only when the grain of the veneer is perpendicular to that of the substrate.
Som
Hmm? I'm not entirely sure about that, though. Running the veneer horizontally to match a solid wood drawer front's grain direction I'd say was historically only somewhat more common than running it vertically. Whether horizontally or vertically orientated the drawer front would have been frequently embellished with cross banding, stringing, bosses, roundels, etc. On modern drawer fronts which are veneered my observation is that for the most part the drawer front is more often than not man-made board veneered on both sides and lipped on all edges. In that case I'd say it's probably or certainly more common for the veneer's grain to run horizontally. Slainte.
