StevieB
I know there are a couple of members here who work with leather so I am hoping for some advice and guidance as a complete newbie to this craft. My son (for complicated reasons) is after a number of small boxes, which I can cut from 3mm plywood and assemble. However, he would like a lid to be part of the design to prevent the contents from falling out. Being 3mm ply, I cannot easily attach fixings to this or hinges. I cannot go to thicker timber for this project. After playing with some ideas and using google images and pinterest (which I find to be a fantastic way to gain ideas) we have identified this type of thing as a possibility:
I have sorted press studs and can see how these will work, but am struggling to know exactly what type of leather would work and how to attach it to the back of the box to form the hinge. Ideally the leather would need to be soft and flexible (a piece of ply is glued to the inside of it to make a solid top internally to the leather). Looking at leather suppliers, I am guessing 3mm leather will be too thick and hard so I need to go for 1-1.5mm, but looking at the image the leather seems to be as thick as the timber sides, which would be 3mm? In terms of glue I would guess epoxy but happy to be convinced of alternatives - the box will be regularly opened and closed so it needs to be strong enough to cope with this. I would also like the glue to be fast curing - I always struggle with epoxy and invariably the 5-10 minute stuff I identify still has a setting time of hours to fully harden, but I suspect superglue will not be up to the job of daily usage. I could superglue and then rivet, but that adds an additional complication as it could only be done after the box is made, whereas the press stud will be fitted before assembly. So I guess my questions are:
Any recommendations for leather suppliers at a reasonable price? I do not need a whole cow, but a range of colours would be good if I can get smaller sizes of soft flexible leather.
Any recommendations on glue for leather to plywood?
Thanks!
Thanks!
