I'm doing the internals of the kitchen cupboards, the roof of which is curved. So, time for some spiling! I decided to use a tick stick:
You stick a bit of scrap in the location, and mark up the position of the tick stick with its end egainst the curve....then transfer those markings to your work-piece. There might be a piccie of that later.
Here's a fiddle being made for the edge of a shelf (stops stuff falling off when in transit):
.......and just to show that I know how to make mitres:
I'm not sure why there isn't an in situ photo of that lot.......but there will be shortly.
Here's the wine rack under construction, starting with the face:
That's a number 78 rebate plane followed by a number 79 side rebate plane to trim to the exact depth to take the 6mm ply. The next bit was something of a pig. I didn't have a hole cutter of the right size, so I worked out that with a smaller one and a rebate cutter in the router, I could achieve the diameter I wanted. I sharpened the hole cutter, and attempted to cut a hole:
It burnt, and then seized up completely (despite being newly-sharpened, and waxed), and didn't achieve more than about 4 or 5mm depth of cut. I patiently did this on both sides all around, to mark the holes and give me a reference. I then roughly cut out the bulk of the waste with first, a coping saw, and then with a jig saw:
Given that I had 4 or 5mm to play with, I used a trimming bit to take this all the way through:
I could then move to the other router table (yes, Mike, who hates using a router, has TWO router tables!), and use the bearing-guided rebate cutter to enlarge the hole by 20mm:
Obviously, with the bearing being at the top, I couldn't go all the way through........so back to the other table to finish off:
Then, a guided chamfer bit put a little chamfer on both the inside and out:
That's enough routing for a while. Like, until August.....
There are some internet points at stake to anyone who can work out what this little cut out is for. It's the real reason for the wine rack, being as it holds approximately my annual consumption:
The following is another product of spiling. It is the side of the wine rack, and here I am starting to work out the layout and construction:
Transfering markings from one side to the other:
........and then (another missing photo) after gluing and pinning some bottle-bearers into place I did a trial dry fit:
.....before moving to the teardrop:
