Mike builds a teardrop (Electrics)
When you're out and about with it I'd put money on someone asking where you got the wood effect plastic or has it had a vynil wrap. :ROFLMAO:
Blimey, really? I hadn't thought of that. You may well be right.
Having finished the cedar strips on the main body of the teardrop, I thought I would play about a bit in the workshop for a while. On my list are an overhead shelf, and the planted-on door surrounds for the 2 side doors. I cut up some sapele:
The overhead shelf has two functions. Firstly, it is a shelf for nick-nacks...glasses, wallet, keys etc. Secondly it is a mounting point for our reading lights, and a place to hide the wiring. I've always had it in mind to make it with a curved face. I set the bandsaw to 18 degrees:
Of course, it was only when I had ripped all the strips that I realised I should have set it to 9 degrees. So I did a lot of careful planing:
Because I had no good way of clamping, I did a 3 stage glue-up. Stage one was 3 lots of 2 strakes:
When that was dry, I glued 2 of those pieces together:
When that dried, I checked out the angles and adjusted with a plane. I wasn't particularly careful because getting to 90 degrees at this point wasn't critical. I then glued up again:
When I de-clamped (ie took off the tape) I roughed it to shape with a variety of bench planes:
I then had to make a decision about whether I would continue the Gaudi-esque theme, or go for something more uniform:
I eventually decided on the latter. I screwed on an extended-height fence, and used the planer to bring the 2 faces to right angles:
Note the gaps in the coopering. This was the result of not being able to clamp, and some of the staves springing to a bit of a curve when I cut them originally. I decided to fill them with thickened epoxy, which is great at gap filling, and great at flowing into thin gaps. I taped up to stop it just running through:
I collected some sawdust from the bandsaw, and used it to thicken up some epoxy. I pushed this around internally (this won't be seen):
In amongst all that, I also cut some half-laps for the door surrounds, and glued them together. Note the pinch sticks for checking diagonals:
The funny thing about those corner joints is that they are temporary. They won't exist in the final piece. Take a look at the drawing of the doors from my first post:
Teardrop side elev.jpgThe door surrounds have rounded corners, which means these square corners will be cut off. I am doing it this way because I remember the difficulty of gluing up all 8 pieces of the frame at the same time when I did the internal versions, months back.
Whilst the glue was drying on the door surrounds, I carried on shaping the shelf:
I took a pattern, and went and offered it in place:
This allowed my to get the shaping for the edges of the shelf:
I took some pinch sticks across to the teardrop, and measured the gap. This enabled me to cut the shelf to length:
I settled on an elliptical shape for the shelf openings, and cut a template from cardboard:
Marking it was easy. Cutting it wasn't. I had to do it with a jigsaw, and I had to do a rolling bevel. Where the curve of the ellipse went around the curve of the shelf it burnt, and it cost me a couple of blades. I cut with the pendulum motion at its lowest setting, and went very slowly and carefully, but still left myself with a lot of cleaning up to do:
I tend to only use sandpaper for shaping, not finishing. There was quite a lot of shaping to do here, though, and I went through a bit of 60 grit:
I offered it into place:
As I said, this shelf acts as conduit for some wiring, so I cut all 4 corners off to allow for the cables:
After lots of work with finer grades of sandpaper, I finished off with a card scraper, then cleaned up the workshop. After wiping off the dust with some white spirit, I mixed up a lot of 1:1:1 mixture, then slapped it on and wiped it off in the normal way:
Thanks to @Dr.Al I had recently bought some sealable plastic bags for storing paints and varnishes, which is why I made up an excess of mix:
I'll give this 4 or 5 coats in total, by which time I should be able to start coating the door surrounds.
Back to the door surrounds. You may recall that I'd built the basic frames. Now it was time to do the corners, so I built a jig:
This produced most of one side of a half-lap joint:
I don't know if I've ever mentioned it, but I hate routers:
That meant cutting out, grain matching, and gluing in a piece:
Most of the corner piece gets cut away, so I'll get away with it even with the most discerning inspection.
I had to fix the template with some filler:
Then after completing the routing phase of the job, there was a bit of tidying up to be done:
I then offered the corner pieces in place, one at a time, and used them to locate a piece of ply to act as a router guide. I also hot-melt glued a scrap on the other side of the joint so that the router base didn't tip:
After doing all the routing for the other side of the half-lap joints, I could then glue the corner pieces in place:
I carefully made yet another template:
I roughed the waste away with a jigsaw:
......and followed up by clamping the template in place and using a trimming router to get the final corner shape:
For some reason, I had done these door liners differently from those on the inside of the door. The other way was better. I took them to the bench for a tidy-up (workholding was a challenge):
The issue with the subtly different corner design showed itself on the other side. The grooves for the seal ran out of the edge:
You can see that I scratched the groove around the curved corners. You can also see that I had a problem with some unwanted grooves. I blocked up, and filled the offending grooves (x16) with epoxy thickened with sapele dust:
I've got away with it, because all that will be entirely hidden by the seals. Still, mistakes like that shouldn't happen.
In the meantime, I'd applied sufficient 1:1:1 to the overhead shelf, put in a central divider to help with fixing it, and fixed it in place:
Well, it looks pretty clear that your accident hasn't affected your level of patience and your appetite for getting on with things! 👍
But I did find myself wondering why you'd started building your own Scalextric track...🙂
Back to the door surrounds. I rounded over the inside and outside edges of the outer face:
Believe it or not, that will eventually be the same colour as the overhead shelf, but as it will be covered in epoxy to make it waterproof, that's not happening just yet.
I'm still only able to stand for an hour or two at a time, so I'm really fiddling about with little jobs until I am fit enough to tackle some of the more important stuff. Next, I thought I would make a corner detail which hides some wiring in the sleeping area. I have lots of cedar strips left over, so instead of cutting this from solid, I thought I would laminate it. First, I made a template:
Then I made up a pattern board to that shape:
And finally, I mixed up some thickened epoxy and glued the laminates together before clamping them to the former:
Whilst that was drying, I found another small job: the tongue box. I wanted to make this with curved front corner, and laminated from the left over cedar strips. I did an experiment to see how tightly it could be bent:
That's a 150 radius. It wasn't without its failures, though:
......and the steam pipe clearly needs better support:
Meanwhile, the laminated corner pieces popped off the former, with no spring-back:
Finally, I spent rather a while making up a former to bend the cedar for the tongue box:
You'll note that I supported the steaming pipe a little better. After firing up the wall paper stripper, I started steaming pieces around the former:
Unfortunately, 2 successes and 6 failures is an unsustainable rate of attrition:
...........so I am going to have to come up with another plan.
As we haven't had 6.40 pm yet today, I deduce that you're not a big fan of having a leisurely lie-in, Mike?!
That's a compilation of 2 or 3 days work, Andy. I'm always up by 6.40am......but never in the workshop.
That clock helps sum up my current limitations. It normally hangs on the wall. It stopped. I managed to nudge it off its screw and replace the battery, but I can't get up to put it back. I think ladders are going to be off the agenda for a month or two yet.
I'm sure you are all desperate to find out how the laminations worked out. Well.......
Their principle job is to hide some cabling, and to mount our bedroom light switches. I couldn't think how I was going to rebate the back for the wires, but I thought I might as well just do the straight bit by hand. I got out a rebate plane, and quickly did the job:
Whilst I had that out and working nicely, I thought I'd give it a try around the curve, with little hope of success. It worked like a charm:
I went to the teardrop and test fitted them:
Now, obviously the other one is just a mirror image and I'd be wasting your time showing you a photo. So, here it is:
Oops! Spot the barely visible little scarf. Yep, when I did my first lamination , I had taken my pattern from the original pattern for the teardrop side wall, rather than from the teardrop itself. I forgot all about the board I had fitted to the underside, so my pattern was actually taken from the wrong place. It's no big deal. I obviously corrected the other side, and these things are going to be painted, and then hidden by a foam head-board:
Moving on to the tongue box. This is a storage area on the draw bar (tongue) of the trailer. You remember my attempt at steaming the shape in one piece had been a failure, so I set about doing it another way. I sawed up some 45x18 redwood ("pine"):
Then using a drawing to obtain the angle, I set the fence on my planer, and worked my way though the pile putting an 8 point something degree angle on each edge:
The two outer ones needed a rebate, which I thought would be easier to do before it was all glued up:
I then carefully laid all the staves out, and taped them up:
Then, I carefully flipped it over and added some glue, before rolling it up and taping it:
The following day, I ripped that 180 degree piece in half to give me two 90 degree pieces, before planing and sanding away the facets. I finished cross-grain (60 grit), because this is all going to be covered:
I made a little cut-out to check the curve with:
These pieces each needed a rebate on the other edge, and as I couldn't hold the work, I couldn't plane them. So, I set it up at the correct angle, and hot-glued a bit of scrap on so that I could run the piece over the router table:
Finally, I corrected the rebate I had done the day before:
I thought I would clean up the inside a little, using an old woodie:
Unfortunately, in the process I broke one of the glue joints:
Twice:
How to do a rebate around the curve:
I couldn't come up with any practical way, so just knifed a line, and chiseled:
Good enough! So, I used if to mark out the base of the box in the last piece of phenolic ply:
I offered up the corner pieces:
This mean I could then measure and cut the cedar strips:
I made a pattern, and cut each one from that. I hot glued a couple of them into place to hold the corners in the correct position:
I could then start the process of gluing in the strips:
PU doesn't take long to dry, so I was able to try that in place on the base:
I took a different approach with the side pieces, because there was nothing to fasten the back edge to. I just glued up a "sheet" of them:
Note the folding wedges. When that dried, I cut a straight line up the middle:
IMG_0374.jpgI glued and pinned the front and corners to the base, then took it to the trailer to off it in place:
I had already made a quick pattern of the angle it meets the teardrop:
So I was able to cut the back edge of each side piece, and glue and pin them in place:
I need a frame at the back to hold the whole box against the teardrop, but also to provide a location for fixing the hinge for the lid. I grabbed some more pine, and set out my pieces. With differing thicknesses I decided on a stopped bare-faced mitre:
If I didn't brace that frame, I just know I would have broken it:
With the frame dry, I could set out the top and cut the top edge. I thicknessed a couple of pieces of scrap, and cut a bit off the end of one to use as a marker. These pieces acted as spacers to raise a flat board a set distance, with the marking piece then taking the line down to the same level:
With a sloped top, I then offered everything up to the teardrop:
I quickly realised the slope was too slack. I don't want water pooling. Back to the workshop, where I repeated the process of packing-and-marking:
I'm happier with this slope:
Finally, I'll tell you that all of this is going to be covered with a technique now known as "Poor Man's Fibreglass" (PMF) but which has been a standard boatbuilding technique for centuries: paint and canvas. So this box will have a painted but textured finish.
I think, with all these fiddly curved bits fitting so neatly together, that we have all guessed already that this whole project is just a practice exercise for when you embark on building Tally Ho II and you've just confirmed it!
Unfortunately......
My wife exercised her veto over a boatbuilding project. The teardrop was very much a substitute.
Wonderful to watch as always. Barrel makers have curved planes for the top grooves but obviously it’s not worth you building one just for your rebates.
I think that when eventually you’ve run out of things to keep you occupied Mike and you’re moping about and getting under her feet she will be glad of a boat build.
I bought some foam for the headboard, and cut it using a 1970s electric carving knife, which is just perfect for the job:
Next, I took a pattern, and started work on the trim pieces under the roof which will cover some wiring, and locate a couple of switches. Initially, I was going to do something much fancier, but the geometry just wouldn't work out:
That's an old piece of skirting board, which did the job nicely:
The other side needed a couple of bits gluing on:
I spokeshaved a round-over:
Those will be painted.
Another little job was carving a shallow line across the doors either side of the windows:
...which I then filled:
I thought I might build the lid for the tongue box by using the torsion box technique I used previously for some work tops. I used 3mm plu for the top and bottom, and strips of 12mm ply for the separating matrix:
Here it is glued up and under weights:
I had put the top sheet on over-sized, to be cut down and planed to matcvh the lower:
It needed edging in something solid, so I planed up some redwood:
The second one was made of fairly knotty wood:
To avoid that bleeding through the paint, I drill the knots out to a few mm with a Forstner bit:
.........and filled with a 2 part filler:
Right, I might need some input here. For the entire time I've thought about this project, I've always had a bog-oak trim around the outside (junction between walls and roof) in my mind. However, I have always worried about bending bog oak around the 200mm radius curve of the roof, and with the amount of wastage it would cause trying to get good straight pieces in long lengths out of the stock I have. Just on a whim, I thought I would do so ebonising test pieces on ordinary oak, because I won't have any great problems bending it, nor with producing long straight pieces. From ebonising I've done in the past, I know it's pretty colour-fast, but can anyone see any issues with steam bending/ ebonising/ epoxying/ and 2-pack-varnishing oak?
Here's the experiment:
It's more distinct in real life. Surprisingly, the blackest black came from the oak which I had pre-stained with the strongest tea I have ever made, and then ebonised. The one I expected to do best.....Van Dyck's crystals followed by ebonising, producing a pretty poor result, probably worse than just plain ebonising. So it could be that the outside of the teardrop is decorated with tea and Pink Floyd......which is rather fitting.
I helped someone out a few days ago. They had a teardrop they were renovating, but couldn't fit the "hurricane hinge" themselves. These are also known as a snail hinge, or a catering hinge. Next time you're queuing up for a burger or an icecream, take a look at the hinge above the opening hatch. It obviously has to be watertight, and it's almost certainly one of these:
The left hand component in the above images is the upper one (note the gutter). It was good to have the practice fitting someone else's before I come to fit mine a week or two.
Finally, I've been sanding the outside of the teardrop. I is actually pretty easy to do with a belt sander.....so thanks for the offers of ROSs, but I'm managing fine without:
And a fun aside. My wife went away with the grandkids for a few days leaving me home alone, so I took the opportunity to sleep my first night in the teardrop. The wedged-in door was the only issue, but otherwise I was very comfortable (on a self-inflating camping mattress, which will be the permanent mattress).
I've no experience of bending oak but I can't see any downside to what you suggest.
The only other thing to mention is that I've seen it mentioned (probably in a forum post or a YouTube) that leather dye can be a good way to get a deep, permanent black.
My attempts at ebonizing don’t give me enough knowledge-sorry. But why not leave it till after you’ve bent it?
Rather than drilling out knots Mike you could have just slapped some Shellac over them? I’m fairly sure that’s all that’s in knotting anyway.
Very complex build and brilliant illustrations. Another thing that works for ebonizing is black fountain pen ink. It's sometimes used by luthiers when they want to fake an ebony fretboard.
.....Rather than drilling out knots Mike you could have just slapped some Shellac over them? I’m fairly sure that’s all that’s in knotting anyway.
I've done that over the years, but found that now and then the sap finds a way of getting through or around the knotting.
These are torture boards:
They're just thin flexible boards with sandpaper glued on, for cleaning up curved surfaces. You use them after you've done the rough levelling with a belt sander across the grain. They're horrible to use.
I've been "fairing" the outside of the teardrop for a few days now ....an hour here, and hour there.....and it doesn't make exciting viewing. However, here's a part with wasn't perfect, and my repair. Unfortunately, there was a low point on my go-faster stripe:
I cut out a 3 or 4mm thick piece to insert, and used it as a template to knife, rout and chisel away the ash, without touching the bog oak:
I then sanded that down to this:
I think I'll get away with that.
Today I received a delivery from 12 Volt Planet:
The principle bits of kit are a DC to DC charger, a mains smart charger, a solar controller, a battery monitor, various fuseboards, buzz-bars and consumer units, and assorted cables, fixtures and fittings. A lithium leisure battery and a flexible solar panel will be added to this hoard in due course. Mounting and connecting that lot will be a big headache for this ignoramus.
The principle bits of kit are a DC to DC charge.r, a solar controller, a battery monitor, various fuseboards, buzz-bars and consumer units, and assorted cables, fixtures and fittings. A lithium leisure battery and a flexible solar panel will be added to this hoard in due course. Mounting and connecting that lot will be a big headache for this ignoramus.
Good to see the Victron products you bought Mike. I have used them extensively in my offroad caravans and they never missed a beat. The BMS is superb and gives a wealth of information - as you probably know. Another good choice is your Lithium Battery. So is the MPPT solar controller - very efficient.
There seems to be little choice other than Victron. I hadn't wanted to spend so much money, but I'm at the "in for a penny, in for a pound" stage. As for the lithium battery.....when I first started looking at this project 3 or 4 years ago, a 120AH lithium battery was around £400. Find the right offer now and you can get them for £130. I was planning on AGM all along until someone pointed out the lithium prices these days.
Hey, we haven't seen photos of your caravans. I'm familiar with them, but the others here would be intrigued, I've no doubt.
The 120Ah Lithium should be more than adequate for the Teardrop and a very good choice as their energy densities are upper class (lightweight for their energy storage capacities and next level with the number discharges and depth of discharge without damage while maintaining good voltage). Will send some pictures of my 'vans. Hats off for the uniqueness, detail and craftmanship by you on the Teardrop!
@Mike G - I save your posts to read properly on a desktop (most of my browsing is on mobile) as they're better than most of the stuff on YT. I've just gone through this one from start to finish and you've surpassed your usual high standard with the project and standard of presentation.
You are very generous in the way you share your projects and in doing so add a lot to the forum.
Thanks
Thanks
That's very kind of you Robert.
I've been doing electrics for 2 or 3 days. Luckily, I have a friend who is an electrician, so he gave me an hour of his time explaining stuff at schoolboy level. I'm just beginning to get a grip on what I'm doing. I'll post in a few days when it's a bit more together.
Same offered from me as Ian and Bob and others.
Definitely show a detailed WIP with the photos - something I'll endeavour to follow *when* I eventually get to do some proper woodworking rather than the bits and pieces I've put into the forum. I do try at present but tend to get too involved with getting on with it than deciding "take a photo" at this step or the next etc. *Must do better*
In some ways I'm envious of the space you have Mike for your work to take place in.
Thanks for sharing your step by step progress 🙏
I am about to embark on fibreglassing the outside of the teardrop, but I have a problem I've not been able to resolve. I have a number of grooves which are for seals, 2.5mm wide and 5 or 6mm deep. I need to prevent them filling up with epoxy. So, I think I need to fill them with something which is then easily removable after the epoxy has set. If I fill them with silicon, that will keep the epoxy out perfectly but be a pig to get out. If I were to melt wax in, I'd need to tape up either side of the groove to keep it neat. I thought of putty, but the oil would stain the wood (sapele) which is going to be on show a bit. Can you guys think of a pragmatic solution?
Erm, when luthiers use specialist binding materials like abalone etc, they need something to fill the adjacent groove so that the glues doesn't stick. After gluing the shell, the non-stick material is removed so the next puffing layer can be fitted.
I've heard of teflon and ptfe strips used for this.
I would suggest researching luthier suppliers, then perhaps research their suppliers for your larger thicknesses.
EDIT. You might not even have to buy the complete lengths of grooves on your workpieces, because you wouldn't glass the whole thing in one go, and the ptfe is reusable. So I've just saved you a bit of money. :)
