the bear":d15gejgr said:
Still awesome
Ref the cleaning the bricks, does it come off easy or require a brick acid? My builder has just used some to get some old plaster off some face bricks as we knock down my utility/conservatory and rebuild the old corner of the house and I was amazed how much difference it made.
I recon the rendering will be done by Friday?
Scrubbing brush and water, and 5 minutes of effort. No problem at all.
Yeah, from expecting this to take 6 or even 7 days, it looks like it will be done in 4 if I can keep ahead of him with scaffolding.
Halo Jones":dlk8l35l said:
No pictures for me on my phone or computer :(
(all through chrome)
I've posted these in exactly the same way as all of the previous 3 years worth. If you can't make it work, drop one of the mods a PM.
Malc2098":143757lk said:
Oh, lovely. I absolutely love the curvey corners.
In the side of Tiverton where I live, many of the late geo/early vict house have curved corners and roofs.
It makes the street scene much less harsh.
Beautiful (until someone stuck a bloody great red-brick thing in the background).
Yes, you're right there, Mike, but some of the existing mill buildings, including the school, still survive. He came down to Devon after the Luddites smashed his machinery up north somewhere. He started again down here, where water power was plentiful and the mill has been here ever since. It had a fire and was rebuilt as a bloody great red-brick thing in the 60s.
https://en.wikipedia.org/wiki/John_Heathcoat
Tusses":avbj4bp6 said:
I bet you must be excited like a big kiddy Mike !
Such a huge difference happening so quickly :)
Yes, to both, although "knackered" is more to the fore than "excited" at the moment.
Finished!!
The whole building is done in only 4 days, some 4 days less than I'd allowed for, using 61 bags of lime (19 less than estimated). My hands are ruined, but other than that, I am delighted. So delighted that I'm going to have a few days off. Anyway............photos:
The grey line below the windows in the last photo is lead flashing, built in now in the hope that we get permission in due course for a conservatory. It's going to look pretty silly if we don't!
Looks hellish, I take it the plasterer was on a job rate and not a day rate :D
No, he was on a day rate. He got a bonus.
Wow, Mike, Wow !!!!!!!!!!!!!!!!!!
:text-bravo:
Looks fantastic. Enjoy the off days, relax with a couple of frosties.
Thanks guys.
I've had a day or two away, so have not seen the latest comments until now. Looking forward to getting stuck in again tomorrow.
Stunning work, amazing you managed to find a plasterer who could keep up with your work rate :lol:
That conservatory on the back, I assume it will be something equally special built by you rather than bought in?
Thanks Matt.
Yeah, the conservatory would be home-made. I don't know if it would be special, rather just simple and clean-lined.
Attention turns temporarily to the porch roof. Here is the junction between the roof and the render, prior to starting work:
I cut some tiles in thirds, lengthways, and mixed up some of the lime render stuff, then did this:
This is a really old traditional detail, done to keep water out of the junction, but you may remember from some while back that I had also done lead soakers up this roof/ wall joint, so this is something of a belt-and-braces approach. I don't think the modern lead cover-flashing with render drip bead looks any good on a period property, so I've done it this way instead. It has the bonus of kicking the dropping water a few inches away from the wall, so it will all go into the gutter without the need for a bodged in bit of lead.
Note in the last photo that I part-tiled the northern roof of the porch. This was to allow access to do the ridge. This is the other side at the same stage:
The next task was the verges and the ridge, so after mixing up some strong mortar and cutting some half-tiles, I got on with it, bedding each tile up the verge in mortar:
Then I did the ridge, pointed up the verge, and tiled the canopy over the door. With shorter days, this was quite a full day, finishing by braille:
Time to start work on the rendering of the porch. For a start, all of the Savolit panels were sitting loose in rebates, deliberately, because I wanted to do a little lead detail at the bottom. Here's the lead:
And here is the bottom of a panel:
The panel at the bottom sits in front of an upstand, designed to have the lead between the two. It's easier to show a photo than explain. Inside first, then outside:
Here is a view into the side rebate, with the board fixed back properly in position. This shows the strategy with these render panels, which is to allow for movement and shrinkage in the oak framing. The render will squeeze into the rest of the rebate, meaning that even if the oak frame shrinks considerably there will be no path into the structure for water (or light, for that matter):
I taped up the oak with Duck tape because masking tape is porous enough that it doesn't prevent the lime from immediately discolouring the oak. There is an immediate and dramatic reaction between lime render (and cement, too) and green oak, leading to permanent discolouration. Anyway, I was now ready for render:
The render depth is about 30mm here, which is a lot. So, I am going to build it up in two layers. Here is the first coat, called a scratch coats because it gets scratched to form a key for the second coat:
Oh, and as a fun little aside, you know how it is when you knock something together quickly as a temporary measure just to get yourself out of an immediate problem? Well, those things, in my experience, usually hang around for at least 30 years. Here is my plasterer's hawk, made decades ago for 5 minutes of plastering, and still going strong (= as badly as ever):
Well, to be fair, I haven't watched Strictly for at least 5 years now.
Jimmy Mack":l9rplmj7 said:
I have a 'temporary' home made hawk somewhere [emoji6]
Ditto
(In fact it is probably the one made by my father when he was helping me plastering on my very first house)
Ditto
Ditto that. Although I have never really plastered, just filled a few holes.
The first three panels consumed an awful lot of render, but more importantly, took two coats and a long time to dry. I decided to pack out the Savolit board with another sheet so that I could finish with a single coat of render, and that coat would go off relatively quickly. So, I glued & screwed some board on like this:
This still gave room for squeezing render into the rebate. Then it was just a question of applying the stuff and troweling it up at the appropriate time, then sponging it. Half a day's work, then a few hours doing other things before coming back to do the sponging:
Tape on, above, then tape off:
You'll note that I've also done the fillet up the canopy roof. That gets cleaned up tomorrow.
What did you do about those misaligned pegs in the apex of the porch?
Looks excellent of course but I reckon it will look even better when it has weathered a little.
Andyp":1mpa9rnh said:
What did you do about those misaligned pegs in the apex of the porch? ......
Sworn at them, every time I've passed under them. No-one else has spotted it yet. If anyone does, they'll be covered up before you can blink.
I am not surprised (that no-one else has noticed).
Mike..this render/plaster that you are putting on, is this some sort of portland cement mixture? And I am assuming that it is the same stuff on the roof ridge, would that be so? Our plaster would not have chance outdoors. Your render must be tough! Looking good!
bill
No, Bill, it isn't cement based. It is lime-based. It is the modern version of the ancient lime/ chalk/ hair render which has been used on the outside and inside of buildings for millennia. Cement-based render is what destroyed this house to the point of near collapse in the first place, in a matter of only 40 years. Cement renders are impervious to moisture, and thus wrap the house in an external vapour barrier. Imagine putting the house inside a giant plastic bag, but having sources of heat and moisture inside the house. The warm moist air inside meets a cold impermeable surface at the inside face of the render, where it condenses, and the water runs down and sits on the sole plate, with no way out. Naturally, the constantly-wet sole plate rots. Further, cement render is rock solid. The frame it surrounds is timber and flexible (and rotting!). This means cracks are inevitable, which is another source of water into the structure.
Lime render, on the other hand, is flexible, and "breathable", which is a shorthand way of saying that it is vapour permeable. It allows moisture through it in the form of vapour, whilst keeping out water droplets (like Gortex). When taking off some old bits of render, larger chunks of it felt somewhat like a thick carpet: you could bend and flex it without it breaking.
This lime render, as per the original, has no sand in it. It was mixed with chalk. Sand almost always has a clay content, and clay shrinks, so even a lime render made with sand is likely to crack or craze somewhat. Lots of renovations in the last 30 years have used lime render, thinking they were doing the right thing, but those renders used sand. Apart from the mortar in the bottom 2 or 3 courses of brick, in the ground, this house was built without any sand. Both the mortar and all the plaster/ render were mixed with chalk. The only difference between that old stuff and the render I used is that the hair element has been replaced with a modern poly-something fibre (hair is really difficult to source, apparently, and Chinese goat hair is no more authentic than poly-something). Further, hair does rot in the end. I guess the other slight difference is that the machine mixing and grading, and the lab-controlled consistency of ingredients means that the modern lime/ chalk render is likely to be of a much more consistent mix than the original, which would have been mixed by hand on site.
As for the ridge.......no, I did those in a strong white cement/ sand mortar (same as the brickwork, but twice as strong).
