Cabinetman
- Joined
- Oct 11, 2020
- Messages
- 5,694
- Reaction score
- 1,383
- Location
- Lincolnshire Wolds + Massachusetts
- Name
- Ian
As you may know I am in Colonial Williamsburg in Virginia. Helping newly acquired Daughter move in and I am building her an L shaped bench with inset tablesaw and chop saw.
It is being built in a garage with a large covered area outside which is super useful shade in the strong sunlight here. Glazed brick walls and a concrete floor which seems to slope in every direction all at the same time lol, there is a large shelf built into the wall of the garage which we are incorporating into the design.
Started with the framework onto the walls.
Then building out the L shape, Sarah Is very artistic and any visual anomalies jar enormously. All leg spacing is critical to her design and they obviously have to take into account the uneven floor, not easy determining the position of the leg then holding up the rail against the leg balancing a 12” level on top whilst marking the height taking into account that it’s CLS with rounded edges - on you own, the air has been a little blue at times.
Then comes the tricky bit, building in the drop boxes for the saws so that the top surfaces are spot on level with the 18mm ply top.
At this time I have got as far as adding the vice, which is an American make called Yost, seems pretty good, it’s a 9” across the top of the front face with quick release, very like a Record.
Vice ( or Vise as they say here) installed with lots of 2x4's beefing up the area around. Four 3” Coach screws (lag bolts here) fastening the vice to the underside of the beefed up area. More later. Ian
