More boxes
mailee
I have been building a couple of cabinets last week. One is a tall unit for files and the other is a small wardrobe to fit over some stairs in a box room. Again these are made in MDF and painted with Morrells 2K. There is a door to go on the tall unit and a rail to fit into the small robe.
Looks good as always! What equipment do you need to pull off a successful 2K finish, as this is a look I would like to use on some of my MDF furniture?
Hello and thanks Erich. To use the 2K I have a large 200 ltr compressor with an output of 15CFM. I use a HVLP gravity fed gun with a fluid tip of 1.7. I would also recommend an air fed mask if you are using the solvent based as I do. HTH.
Thanks for the feedback! I think it would be easier for me to have it done at this point as I don't have any of the proper spray equipment required.
