I've mentioned before my barn and it's subsequent conversion or half of it to a workshop. Note 99% of the work NOT done by me
Just so you all now how grand it isn't I'd thought I'd share a few picks.
this is how it was when we moved in.
You can't see the slope on the floor but it was about 3 inches going down from the opening. Situated on the downslope of the garden and facing west we soon discovered that we needed to plug that hole.
We also added a drain to take the rainwater away from the barn and into a ditch away to the right.
The workshop is only to the left of the doors
Above the workshop
I did dig the ditch for the power cable
This existing power to the barn was taken off from this box under the lawn which was in turn fed from a outside lamp in the middle of the garden. The cable was so close to the surface I was able pull it up by hand all, 15m of it.
The inside
I did do all the surface mounted electrics and paint the walls.
It does not look this tidy any more.
Above the workshop
The inside
