And you know this how? Exactly what incident lead up.to you espousing this knowledge? Hmmm?Nowt wrong with that. Just be careful where Willy is . He's a bit of a sensitive soul l
The argument against them goes: if you are sitting or standing in a pool of water, like a bath or a shower, and also in that water is either a metal drain pipe or a tap fitting with a metal supply pipe, then there's a low resistance path to ground passing through you. It's the immersion of the human in water that's important; the reason it doesn't apply to kitchens is that most people don't spend significant amounts of time sitting in the kitchen sink.I’ve never quite understood our aversion to bathroom sockets. Arguments against them could be applied equally to kitchen or outside ones
That is a fair point. But compulsory RCD protection goes a long way to mitigate that. What you could do is insist that, if there is a bathroom socket, that the taps/drain be non-earthed, simply confirmed with a wander lead during a normal EICR. Even with a socket 3m away, this could be defeated with a simple extension lead. And what of the French?!The argument against them goes: if you are sitting or standing in a pool of water, like a bath or a shower, and also in that water is either a metal drain pipe or a tap fitting with a metal supply pipe, then there's a low resistance path to ground passing through you. It's the immersion of the human in water that's important; the reason it doesn't apply to kitchens is that most people don't spend significant amounts of time sitting in the kitchen sink.
The bigger counterargument is that most drain pipes are plastic these days, but they who write the electrical regulations don't want to make people inspect the whole house's plumbing to determine whether the sockets are compliant.
As a vet in a previous life, I can tell you your problem started just here^Tried to wash our cat
Our cat took the same view as you, but to be fair, it was the first time in 17 years that we’d ever felt the need to wash her. Greasy.As a vet in a previous life, I can tell you your problem started just here^our cat is self-cleaning, thankfully.
Welcome to the french way of life..or deathWe have a power socket in our bathroom. A friend of ours had a leccy inspection and was marked down for NOT having a power socket in the bathroom, "in case someone wanted to dry their hair". Absolutely bonkers.
That's almost the case with our Labrador if we try to wash her. She happily jumps into every filthy pond or puddle and rolls over in anything disgusting but clean water is a no no.I’m amazed you aren’t shredded trying to wash a cat! If it had been scrubbed every week from birth you might have got away with it, perhaps a dry/powder shampoo next time?
