Phil's Workshop build
9fingers":38kefri3 said:
philjones86":38kefri3 said:
I think that stuff is a clone of Thompson's water seal which is ok ish for a while and then needs redoing.
Synthaprufe aka Black Jack is a little better and can go onto a damp surface as it is water based bitumen emulsion but it is filthy to use in a visible location and also will benefit from redoing every few years.
If you really don't want to do the concrete fillet - which is possibly the best solution, then synthaprufe on the inside up the dwarf walls and overlapping onto the concrete slab is a second or third best.
Not sure on what your intended floor detail is which might make a difference.
Just my 2p but Mike is the guv'nor on these matters :D
Thanks, I think I will go with that option initially for ease and aesthetics
To encourage the water to drain away you could make a small channel with a grinder. Use a stone cutting disc and grind a single channel parallel to the brickwork to the edge of the slab. If you made some sort of jig you could put a slight incline in it to ensure the water runs away freely. It need only be the thickness of the disc, and only a few mm deep, to stop water from pooling in front of the bricks.
