This is not a completed piece but the start of a pierced bowl that I am working on.
I have first turned the bowl to an even thickness of 1/8" right the way around to the little foot. The foot is removed because if I left it until the piercing is done the bowl will be very delicate.
In this picture, all of the above has been done and the rim divided into 6 and lines brought down from that then a line around the bowl a little way down from the rim.
I used the computer to make six oval shapes with a cross through the centre and cut these out sticking these to the bowl and marking out. Having the six paper templates allowed me to see that everything is lined up and evenly spaced and the vertical line also helped with this.
It took me all afternoon to do this as well as mark out the piercings in each oval.
The picture shows the bowl with all the ovals marked out as well as one with the bits that need the piercing
I will be adding colour once all the piercing is complete
