You'll remember the saga of my planer thicknesser from a few months ago. Well, all is not quite well. I ended up simply re-wiring the lead from the NVR switch into the junction box on the motor, and replacing the capacitor.
Three times since then the planer has died after a second or two of pressing the on-button, and each time it has been the fuse in the plug. Why would a plug fuse blow instead of the workshop trips tripping? This place was properly wired by an electrician 5 or 6 years ago, so the trips are absolutely as they should be..........so what is going on that might lead to a fuse blowing?
