I made up a test domino from oak that seems to fit okay with a bit of fettling with my block plane.
With that proven it was time to make some for real.
I ripped down down a bit of 14mm oak I happened to have.
Then rounded it over on the router table in four passes.
That got the two bits looking reasonably shaped.
I then used the block plane to finish off the shape.
That gave me two over long pieces ready to go.
Next I needed to work out where to put the dominos and make sure they were in the same position on both sides. I used masking tape so I didn’t have to rub pencil marks off the wood afterwards
I clamped on a board to give an extra frame of reference for the domino machine
And feeling brave I went for it!
It seemed to come out alright which was a great relief. Dominos are really quick ways of cutting holes, but really quick way of messing things up if you get it wrong.
And on the other side.
Then on to the mortises for the foot supports
They both worked well.
Then it was on to putting a round over on both sides of the horse.
It doesn’t show much in the photo, but it makes quite a difference, particularly after a light sand.
Finally time to start putting some varnish on it.
I used some polyvine wax finish varnish, which doesn’t add much colour but does seem to be fairly robust.
That’s it for today.
