Sabre 250 Guide Bearings
Peri
Shropshire
Steve.
Went to use my little RP Sabre 250 today to resaw some 3" stock.
I noticed sparks coming off the top back bearing. After a check, the top back, one of the top sides, and one of the bottom side bearings are all seized solid. The ones that aren't seized feel like they have sand in them. (The saw is about 18 months old, it's only had weekend use).
I managed to get a bit of movement in one of the frozen ones by tightening a bolt onto the inner race, and holding the outer race lightly between softwood jaws in the vice, then turning the bolt - but it's obvious that it's dead.
The bearings are 8mm (int), 22mm(ext), 7mm thick.
I'll replace all 6. I don't mind buying quality - are these good? they seem very cheap https://www.bearingshopuk.co.uk/608-zz/
Edit - Bought these https://simplybearings.co.uk/shop/p2010 ... _info.html - they look more like the real thing.
I use Simply Bearings if I ever need to buy any. Bearings always strike me as cheap, but the choice can be bewildering.
