Screw-adjusted plough plane
Suffolk
Mike
I have finally had enough of my lever-adjusted Stanley 50 Combination Plane. There is simply too much slop in the system, and I am constantly ripping out chunks and then cutting nothing at all with the merest touch on the lever. So, what should I buy, chaps? Obviously I am talking about a second hand old tool for restoration, rather than some modern boutique mega-bucks thing. The only criteria I have is that it must feature screw adjustment.
I suggest a Record 050 or 405.
Although the 405 is more complicated, as it can do beads, T&G and simple sash, it has a better fence with a fine adjustment. Also, because they came in a nice fitted box, they often come complete and in good condition.
Nice Stanley 13-050 on UK ebay at present, item no 398176408817 starting bid £25 (nothing to do with me)
The 13-050 is a more modern version of the Stanley 45/ Record 405 (the 405 is a copy of the 45). One thing I like about my 13-050 compared to the 405 is the adjustment and sharpening of the nickers. The 13-050 ones are large and easily worked with, the 405 has the smaller three bladed shamrock style nickers which can be fiddly to sharpen.
The 45/405 can use additional hollow/round bases which are very handy if you don't have a set of wooden hollows and rounds. The special bases are hard to find though and can cost a lot more than the basic 405.
I did make a wooden number 8 hollow and round base set for my 405 (details here https://www.woodworkforums.com/showthread.php?t=230103).
I have manuals for both the 13-050 and 405 if you buy one without.
I have a 405 (nigh identical to Stanley 45's) and like it. The closed handle - I find - gives a more positive grasp than the open, forward-leaning one of the 13-050 and it's ilk, where a sweaty, or oily, hand can slip off (allegedly).
I’d look on Facebook marketplace, you just might get lucky with one close by.
Edit: I can see one in Sudbury, is that far away?
Sudbury Suffolk is about 5 miles away. But there are 2 or 3 other Sudburys, including one in London.
It was the Suffolk one, I’m not a complete idiot.
Still available if pull your finger out .
Edit: I may be mistaken in that it is the same version that you are annoyed about.
Apart from location, there are some important differences between the various models.
Looking just at the Record 044, 050 and 405 I'll mention a few.
The 044 uses cutters with grooves on the back. The cutters for the 050 and 405 have a notch at the side. That means it's easy to use, adapt or make cutters for the 050 and 405.
The 044 has a single skate under the cutter, similar to the skate on a wooden plough (but without the locating notch). This is ok for narrow grooves but for wider grooves (or rebates) there's a tendency for the plane to tilt over. The 050 and 405 fix this issue by having a 'sliding section' which supports the nearside of the cutter.
044:
050:
405
That's my long-winded way of saying that I think you'd benefit from having a 405, even if you only ever use it to cut straight grooves.
The notched cutters is definitely true of the Record #405 and the Stanley #45 and #55. I've made lots of cutters for my #45 and #55 (although I rarely use the latter) and I agree it's very straightforward to make custom ones.
The Stanley #50 has the same style of grooved cutters as the #44 - visible in this picture I nicked off t'web:
Perhaps this is different between the Stanley and Record #50s? It sounds like Mike's got the Stanley one and it's that lever adjuster that was frustrating him (something I agree with - my #50 doesn't get used much).
