While I am waiting either for SWMBO or anyone else to help get the worktop indoors, I need another project. This is it. One of the bedrooms aka my study - an L-shaped room, the long-term plan being to make another small en-suite in the alcove (the plumbing and waste are already there).
Background
It's an old oak-beamed house. The floor of the study is on top of these beams which, although this photo doesn't really show it, corkscrew their way as you traverse the room.
When we moved in, the ceiling was plasterboarded over and we got our builder to strip it out and recess it in between the oak joists. The downside is that the ceiling void is now non-existent - about 40mm. I laid chipboard over the joists many many years ago. Packed with little bits of loose wood here and there to fill in the gaps between oak joists and chipboard.
At the time I just went with the flow and the result is that as you go into the study from the door threshold, the floor goes down and then rises as you reach the opposite wall. And as you traverse left, the floor rises and rises and rises. The bit in the alcove is about 2" higher than the door threshold.
And, naturally, being an oak-beamed property there is nowhere to run the central heating pipes which you can see in the background. So these will need to be boxed in decently this time.
A few more photos to set the scene.
This is the door to the airing cupboard. It has been left unhung for the last fifteen years.
The reason why I'm taking up the chipboard is because, after all those years since it went down, I have no recollection of what wires or pipes might lie underneath. No such thing as digital cameras when I laid it.
Plan A was to rip up the chipboard completely and then lay cross-pieces across the width of the room on which the oak floorboards would go. However, the height I have to play with (due to the level of the door threshold) doesn't give them enough meat and I think the floor will be too springy. I may experiment though.
To be continued.
Background
To be continued.
