Teak & Pine Sideboard... (FINISHED)
fiveeyes":jdm7imt9 said:
Yay..nice looking cabinet, Paul.
Even nicer to see you, and the Missus are in good nick.
bill
Thanks Bill. Yep, we're still breathing thankfully.
My tea/coffee mug is a good inspiration, which reads, "Keep Calm And Carry On." 8-)
Andyp":j72631w8 said:
Classy.
I guess you are not driving that coach so much at the moment, hope all is well.
Thanks Andy. I haven't driven a coach for almost 8 months. The coach touring industry is completely broken. I could probably drive National Express, but I'm high risk and I don't need to work thankfully. All is okay here, just keeping busy with various creative projects. Hope all is well your end. 8-)
Rod":3pxx63z7 said:
Really nice Paul, glad you have survived.
Thanks Rod. 8-)
Yes - so far, so good. We all have the long winter to get through now. :|
I hope all is okay with you and your stuff is still behaving. I had a severe Crohn's flare through the summer with several hospital admissions and visits. The tests/examinations are ongoing with three more fast approaching. I was on Infliximab infusion up until having an anaphylactic shock during the third infusion. I've just started a self-injected biological drug - early days but fingers crossed. Our NHS staff are superb.
The regular drinking vessel is a great source of inspiration.
:text-bravo:
Cabinetman":3suncs2d said:
Very nice indeed, love the black stringing on the end panels, what did you use for the back panel it looks sort of a shade of green? Ian
Thanks Ian. 8-)
I was unsure about the end panels at first, but the reason for the stringing as thus, was to keep it in line with the string on the top surface. It took some working out from the beginning, purely because my wood stock was extremely tight. I was thinking about cross banding with some oak construction veneer (between the string and teak on the sides), but the width was so small, I could see what benefit it would give, so I decided to inlay the string straight into the pine panels instead.
The rear and base panels are plywood. I didn't really want to use a man made board anywhere, but I also wanted to use what I already had without buying anything. It made sense to use the ply. It was in good nick and is certainly strong enough, and, painted looks a treat. I used a black vinyl emulsion which I then sealed with a varnish - matt to the rear panel and satin to the base panel. We're very happy with it. 8-)
