Bought this template from Trend. It's for joining worktops but I'm hoping to use it to join the 'sole plates' together on the Orangerie.
I did a trial cut in some ply but if you look closely at the bottom of the cross you'll see that it's not long enough.
The alignment dowels are hard up against the ply so I can;t see that I'm doing anything wrong. Simple fix I know but will contact Trend to see what they have to say. I'm using the correct router bit and guide bush.
